Author Topic: Rear axle sleeve (saver) removal methods?  (Read 10808 times)
Offline ecarter423
« on: January 23, 2021, 05:35:29 pm »
Trying to install new axle shafts, bearings, and seals. Ran into this beaut. while on one side of the rear. Any idea how to get this sleeve out? Not having luck with a cheap slide hammer method. Would a small Dremel cut that sleeve?
Thanks in advance, this is my first square.
Offline JohnnyPopper
  • Old Goof
Re: Rear axle sleeve (saver) removal methods?
« Reply #1 on: January 23, 2021, 05:50:13 pm »
Never seen one used. What is it saving?
So I guess your new bearing won't slide in?
Try the Dremel, see if it scores the sleeve first. I would cut a slot but not down to the actual axle housing. When deep enough, use a narrow flat head (preferably real old and somewhat rounded) to whack and break it.
You will be creating a lot of nasty debris, so stuff a rag real tight into the axle tube just past the bearing race. Brake cleaner wash out, then pull out your tight little rag.
1980 C-10 under construction
Offline ecarter423
« Reply #2 on: January 23, 2021, 06:11:07 pm »
I believe it was used to move where the bearing and seal wore on the axle. Since i have new axle shafts, this isn’t needed. My stock bearings and seals won’t fit with this in there, nor will my shaft go all the way in for the c clip.
Offline MIKE S
  • Member
« Reply #3 on: January 24, 2021, 08:51:27 am »
If you have a welder you can weld a bead on the inside surface of the bearing saver about half way around and let it cool.  It will shrink after cooling and should come out fairly easy.
« Last Edit: January 24, 2021, 09:04:28 am by MIKE S »
  • Old Goof
« Reply #4 on: January 24, 2021, 11:08:15 am »
Very Clever Mike, I will file that one away!
Offline ecarter423
« Reply #5 on: January 24, 2021, 01:40:19 pm »
Took about an hour of slamming with a homemade tee but she came out in all her glory. Didn’t have to cut or weld but it was probably in there way too long. Thank you guys for the responses and help!
Offline MIKE S
  • Member
« Reply #6 on: January 24, 2021, 05:43:10 pm »
That trick was taught to me by an old school machinist who was my uncle I worked for 25 years. Another trick that might help someone on this forum that he showed me that I have used many times is removing screws that are about to strip the head out is to get some valve grinding compound and put some on the end of the screwdriver before it’s completely stripped. It will bite into that screw and you will be able to remove it. Permatex sells it in a squeeze tube.
Offline carmen77
« Reply #7 on: February 03, 2021, 09:11:28 pm »
Thanks for the tip. I’m going to try this. I actually have a stripped screw on my headlight bezel that I can’t get out. It’s not totally stripped yet because I made myself walk away! Lol
I will definitely give this a try.
  • Old Goof
« Reply #8 on: February 04, 2021, 04:38:05 am »
Sometimes it's best to 'walk away' regroup, improvise, adapt, and overcome...Marines?
  • Old Goof
« Reply #9 on: February 04, 2021, 06:11:43 am »
BTW ecarter, that is one rusty square, judging (but not being judgemental) by the rust on the back plate and bolts...
You didn't find it in the ocean off the Philippines or Vietnam, did you?  ;)
Offline carmen77
« Reply #10 on: February 04, 2021, 08:26:52 am »
Great advice!
Sometimes easier said than done.
