Author Topic: Cowl Mounting Hardware  (Read 11815 times)
Offline Mike81K10
« on: February 09, 2021, 06:59:58 pm »
Does anyone know where you can get the plastic posts (studs) or whatever you call them that stick out the back and goes into the holes on firewall under the windshield. Believe they are plastic. Need about 4 of them!
Offline JohnnyPopper
  • Old Goof
Re: Cowl Mounting Hardware
« Reply #1 on: February 09, 2021, 08:13:09 pm »
The ones that press in from the inside?
But to answer your question, no I don't.  :(
I'm going to need some too so I hope the brain trust comes through...  :D
1980 C-10 under construction
Offline Mike81K10
« Reply #2 on: February 09, 2021, 08:21:34 pm »
Yes! I have looked for them online and at the forum's store to no avail.
« Reply #3 on: February 10, 2021, 03:59:07 am »
Do you mean for the cowl seal?
Offline Mike81K10
« Reply #4 on: February 10, 2021, 11:31:50 am »
No looking to mount the cowl panel to my truck. I got the cowl screen on already. There are OEM holes just under the windshield on cowl where fasteners attach or go through the inside of the cowl panel and goes into the holes just under the windshield on the truck. Cannot find any picks of the fasteners. If anyone has some good pics of them it would help.
« Reply #5 on: February 10, 2021, 04:41:09 pm »
Ahh you mean these guys?
Offline Mike81K10
« Reply #6 on: February 10, 2021, 05:31:48 pm »
That looks about right! Should attach from the inside of the cowl panel and poke out to go in the firewall hole. Where can those be found?
« Last Edit: February 10, 2021, 05:34:53 pm by Mike81K10 »
« Reply #7 on: February 11, 2021, 03:53:50 am »
Looks like they are still out of stock. I believe I still have some but will have to check. I had these in my 3D files as well to print. I'll look tonight.
Offline Mike81K10
« Reply #8 on: February 11, 2021, 11:33:37 am »
Thanks VZ!
« Reply #9 on: February 11, 2021, 03:35:30 pm »
2 are like those pictured, the rest are a push in and very difficult to remove without breaking.
Offline Mike81K10
« Reply #10 on: February 11, 2021, 04:45:34 pm »
Hey Zieg, I have two (one on each end of the Cowl Panel - similar to what VZ showed) and I am missing the four in the middle area. All I am referring to is the side of the cowl that goes on the firewall under the windshield.
« Reply #11 on: February 11, 2021, 05:24:45 pm »
I have several cowl panels with the factory ones intact. I'll post pix tomorrow of them
Offline Mike81K10
« Reply #12 on: February 11, 2021, 06:30:00 pm »
Thanks VZ, that will be a huge help. Amazing how these small things come back to get you.
« Reply #13 on: February 12, 2021, 10:54:54 am »
Okay so there are differences in the cowl panel, mainly for larger wiper hole openings from what I can tell. I don't think we ever did a thread here on the cowl panel differences. Anyway, looks like the earlier version all use the same push in body clip and the later version uses the threaded ones on the ends with a u-nut. See pix
I'll look through my body clips and see what I have.
Offline Mike81K10
« Reply #14 on: February 12, 2021, 11:42:23 am »
Believe my truck uses the type in your first three pics. The best, being the white cowl panel (third pic). Wonder where we can get them at and why it is so hard to find them. Seems I am not the only one that needs them. Appears cowl panels are sold, so why not the hardware to mount them.
