Author Topic: Air filter parts  (Read 5445 times)
Offline MY1978
  • Just a girl and her truck since 1978
Air filter parts
« on: April 06, 2021, 01:03:15 pm »
Cleaning up my air filter housing and need to find out where to find these 2 parts........if possible.
Thanks
Offline TexasRed
Re: Air filter parts
« Reply #1 on: April 06, 2021, 01:55:39 pm »
The right is the crankcase breather:
https://www.rockauto.com/en/catalog/gmc,1984,c1500+pickup,5.0l+305cid+v8,1143302,exhaust+&+emission,crankcase+breather+element,4932
The left is for the thermostatic air cleaner system and not sure it's available new anymore.
Make sure the parts fit your year, I didn't use 1978 but 1984 and c1500 with a 305.
Offline MY1978
« Reply #2 on: April 06, 2021, 02:03:08 pm »
Thank you TexasRed.  I found the breather and will order.  Does the thermostatic air cleaner ever go bad?  This one, if original would be 40+ years old.
Offline TexasRed
« Reply #3 on: April 06, 2021, 02:31:00 pm »
Maybe, not sure. A lot of times they hit the trash can for a lot of vehicles. Apparently you can still find the part, this may be it here: 1968-1979 GM Air Cleaner Air Inlet Thermal Vacuum Sensor, plug that into google. It's available from a few sources. Not sure if it'll fit your application.
Offline MY1978
« Reply #4 on: April 06, 2021, 05:23:39 pm »
WOW!!!  How did you find that!!!!  (Air Cleaner Air Inlet Thermal Vacuum Sensor).  I have looked in every parts book I have, the official service manual, and the GM/Chevrolet parts dvd and couldn't find it.  I don't know if this one is bad, but I am going to order one to have on hand.
Thank you, Thank you, Thank you.    :D
Offline MY1978
« Reply #5 on: April 07, 2021, 07:55:07 am »
So, TexasRed, here is my next stupid question.  Is there are right and wrong way to reinstall the temp sensor?  My air filter housing was kicked and it dislodged the temp sensor.  I thought it was somehow adhered in place - apparently I was wrong.
Thanks
Offline TexasRed
« Reply #6 on: April 07, 2021, 01:38:25 pm »
Should be or should have been a clip on the underside of the aircleaner. Some of the photos on google show the part coming with the clip.
I think I may have gotten the last one years ago from rockauto. I remember it being a closeout item and it coming from Sugarland (that's where a lot of the discontinued items go).
Offline MY1978
« Reply #7 on: April 07, 2021, 07:56:39 pm »
Ok, thanks I do have the clip.  I am wondering if there is a right and wrong way to attach the hoses to the sensor connection points - does it matter which hose is attached to a connection point?
« Last Edit: April 07, 2021, 07:59:02 pm by MY1978 »
Offline TexasRed
« Reply #8 on: April 07, 2021, 08:13:53 pm »
I don't believe it matters. It opens when it senses air temperature is too low and allows vacuum to the little flapper in the air cleaner to pull heat off the exhaust manifold. I wouldn't see why it would matter because it should just shut off connection between the two ports when the temperature is high enough.
Offline MY1978
« Reply #9 on: April 07, 2021, 08:19:03 pm »
OK, Thanks.   ;)
Offline MY1978
