Author Topic: C10 6 lug conversion  (Read 14206 times)
Offline 86c10
« on: May 21, 2021, 12:37:48 pm »
I’ve look into doing a 6 lug conversion on a ‘74 c10 so I can run ‘99 and up 6 lug wheels. It looks like I can do this with out adapters by using front rotors from an early 90’s light duty 2500 and rear axle shafts from a k10. Has any body on here done this swap and how do the stock later model wheels fit? I tried searching but wasn’t coming up with any info.
Re: C10 6 lug conversion
« Reply #1 on: May 21, 2021, 04:13:23 pm »
The logical thing to do would be to run wheel adapters for $150 bucks and be done with it.
Offline 86c10
« Reply #2 on: May 21, 2021, 06:49:11 pm »
I thought about spacers but I wasn’t sure if that would push the factory wheels out to far. Either way will cost me about $150.
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: May 21, 2021, 09:44:01 pm »
Other considerations are bearing size on spindles and rear axles. You can cross reference them online, but I would start there.
Then measure the center line of the wheels you want to use/run against the same of your rotors before and after (using adapters)
If not familiar with the term 'center line' it's the mating surface of your wheel to your rotor/drum.
Measure against the width of the wheel to the rear, or inside. Subtract the inner distance from the overall width of the wheel.
1980 C-10 under construction
Offline 86c10
« Reply #4 on: May 22, 2021, 08:12:49 am »
The front inner and outer wheel bearings are the same but I forgot to check the axle bearings. Thanks for the input.
The front wheel bearings are the same but I forgot to check the axle bearings. Thanks for the input
« Last Edit: May 22, 2021, 01:46:21 pm by 86c10 »
Offline Canadian 4X4
« Reply #5 on: June 04, 2021, 05:57:16 pm »
Summit offers a 6 bolt conversion rotor  I used them to run transit wheels everything fit as it should. The 6 lug light duty 90s rotors wouldn't work the caliper wouldn't bolt back up. It's been a few years but I think the rotor was set inward too far
Sent from my SM-A515W using Tapatalk
« Last Edit: June 04, 2021, 05:59:17 pm by Canadian 4X4 »
Offline 86c10
« Reply #6 on: June 05, 2021, 09:04:24 pm »
Awesome, thanks for the info. Did you just run spacers in the rear?
« Reply #7 on: June 06, 2021, 05:32:41 am »
I just ran a 4x4 rear end. You can run just the axles too
Offline 86c10
« Reply #8 on: June 12, 2021, 06:13:55 pm »
Thanks!
