Author Topic: Exhaust Riser Valve  (Read 13186 times)
Offline 85max
Exhaust Riser Valve
« on: July 13, 2021, 12:27:15 pm »
Sorry if this is the wrong place but it's as close to the exhaust as I could find.  I have an 85 GMC with a 454 that has the Exhaust riser valve in the driver's side manifold.  Has anyone taken one of these off?  By the looks of the 84 manual on here, it seems that the valve slides over the studs from the manifold and the donut from the exhaust pipe kind of holds the whole thing together.
Re: Exhaust Riser Valve
« Reply #1 on: July 13, 2021, 12:40:01 pm »
The valve, doughnut, and flange are retained by three nuts and spring pressure.  From the factory, the valve is a metal-to-metal fit with the manifold although gaskets are available through the aftermarket.  Saturate the three retaining nuts and studs with PB Blaster repeatedly over several days to a week prior to attempting to loosen the nuts or they will assuredly seize.
Offline 85max
« Reply #2 on: July 17, 2021, 01:55:02 pm »
Thank you.  I 've had the nuts off and replaced the donut, but there is a leak above the valve to the exhaust manifold.  On mine it looks like there are collars on the studs which hold the valve to the manifold.  Maybe they will slip off over them, I don't know.  Just wondered if anyone had taken this whole thing off before.
