Author Topic: 1984 K5 Blazer 4x4 build  (Read 57160 times)
Offline mercado1211
Re: 1984 K5 Blazer 4x4 build
« Reply #15 on: July 27, 2021, 10:45:31 pm »
There was more to that repair than seeing led to believe. Below the drip rail piece that’s welded in, I cut a portion off the bottom to expose more rot.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #16 on: July 27, 2021, 10:46:16 pm »
After.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #17 on: July 27, 2021, 10:48:04 pm »
The driver door, note damage going right over the body line.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #18 on: July 27, 2021, 10:49:53 pm »
Used masking tape to help keep the body line straight as possible, theory anyway. Filled up to the tape then block sand. Then switch masking tape to the other side.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #19 on: July 27, 2021, 10:51:26 pm »
Good enough I guess.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #20 on: July 27, 2021, 10:52:34 pm »
Passenger door was better, the body line was spared from damage but had dings all over.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #21 on: July 27, 2021, 10:53:15 pm »
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #22 on: July 27, 2021, 10:53:34 pm »
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #23 on: July 27, 2021, 10:55:30 pm »
Usual cracks at the steering box.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #24 on: July 27, 2021, 10:56:07 pm »
Brace kit.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #25 on: July 27, 2021, 10:57:17 pm »
Pulled out the older worn 350 block.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #26 on: July 27, 2021, 10:58:43 pm »
Opportunity to paint the firewall and frame rails, springs and front differential
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #27 on: July 27, 2021, 10:59:48 pm »
Painted core support
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #28 on: July 27, 2021, 11:03:55 pm »
Put a 350 2 bolt Vortec block in it from a 99. Like these blocks cause you get the roller set up and stay more or less true to the build. My opinion anyway. Did have to use Flotek heads though since the vortec heads were cracked.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #29 on: July 27, 2021, 11:04:31 pm »
1984 k10 LWB
1984 k5
1979 C10 SWB
