Author Topic: 1984 K5 Blazer 4x4 build  (Read 59526 times)
Re: 1984 K5 Blazer 4x4 build
« Reply #75 on: April 21, 2022, 06:06:32 pm »
I just went through a bad set of roller lifters. The Melling lifters were perfect. Just get a new set and be done with it. Don't get cheap china ones!
Offline mercado1211
« Reply #76 on: April 21, 2022, 06:26:31 pm »
I thought about getting the auto zone melling brand. Heard they were ok if you check them out well before you install them
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #77 on: April 21, 2022, 07:08:58 pm »
Hey Vile, did you soak those in oil before install or just dropped them in?
1984 k10 LWB
1984 k5
1979 C10 SWB
« Reply #78 on: April 22, 2022, 04:19:12 pm »
Dip them in oil or assembly lube. Never soak lifters.
Offline mercado1211
« Reply #79 on: April 22, 2022, 05:05:32 pm »
One of the lifters I picked up had very small Mars on the side I think it’s ok to run but what you think? It’s a smooth mar and doesn’t protrude from the body.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline Mike81K10
« Reply #80 on: April 22, 2022, 05:24:41 pm »
If the small mar bothers you Good or Bad, don't chance it - exchange it.
Offline mercado1211
« Reply #81 on: April 22, 2022, 05:42:12 pm »
Dang, kind of want to run it I’m outside of Phoenix and the Autozone I found these Mellings in is about 30 minutes out. Probably better off swapping it though.
1984 k10 LWB
1984 k5
1979 C10 SWB
« Reply #82 on: April 22, 2022, 06:03:09 pm »
Is this a factory roller cam block or a retrofit roller cam?
Offline mercado1211
« Reply #83 on: April 22, 2022, 06:20:25 pm »
It’s factory. Block came out of a 99 suburban. I switched the cam to a GM performance ramjet cam when it was built for the second time.
1984 k10 LWB
1984 k5
1979 C10 SWB
Offline mercado1211
« Reply #84 on: April 22, 2022, 09:08:47 pm »
Source of the knock. Guess I can return the lifters I bought.
1984 k10 LWB
1984 k5
1979 C10 SWB
