TODAY is a Great Day to visit our Store and order the parts you need for your classic GM truck ! ! !
It starts up fine, getting 6ish psi at the carb, runs good, no issues. After driving for about 10-15 minutes, it starts to starve for fuel. It usually won't completely die if I use very little throttle, but the pressure drops to 0-1 and I can see that the clear filter near the carb is emptying of fuel. Initially I thought it was vapor lock (even though it felt like it was happening very quickly to be that), so I rerouted the fuel lines away from heat. I also replaced the pump because it was weeping, still have the issue.
