Author Topic: Should sealant be used on the vacuum outlets on the intake manifold?  (Read 4400 times)
Offline Stewart G Griffin
Should thread sealant be used on the vacuum outlets in the intake manifold----like for trans vacuum modulator, vacuum advance etc.?
Re: Should sealant be used on the vacuum outlets on the intake manifold?
« Reply #1 on: September 15, 2021, 06:14:57 pm »
Negative, dry installation, no clamps or sealants with the exception of evap hoses which should have a tension clamp.
« Reply #2 on: September 18, 2021, 01:30:49 pm »
Ok.   But just to make clear, i meant the threads the screw into the intake manifold, not the hoses that connect to the fitting.
« Last Edit: September 18, 2021, 05:42:55 pm by Stewart G Griffin »
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: September 28, 2021, 04:30:56 pm »
I use pipe tape on those threads.
1980 C-10 under construction
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: September 28, 2021, 05:21:56 pm »
Liquid version of the same thing for me.
98 C2500 ext cab longbed
« Reply #5 on: September 28, 2021, 05:49:58 pm »
So let's rephrase the question like this: Should thread sealant be used on pipe threads? Answer = Yes
