Should sealant be used on the vacuum outlets on the intake manifold?
Topic: Should sealant be used on the vacuum outlets on the intake manifold? (Read 4245 times)
Stewart G Griffin
September 14, 2021, 08:44:47 pm »
Should thread sealant be used on the vacuum outlets in the intake manifold----like for trans vacuum modulator, vacuum advance etc.?
Re: Should sealant be used on the vacuum outlets on the intake manifold?
September 15, 2021, 06:14:57 pm »
Negative, dry installation, no clamps or sealants with the exception of evap hoses which should have a tension clamp.
⌠ŻŻŻŻŻ' [☼===☼]
Stewart G Griffin
September 18, 2021, 01:30:49 pm »
Ok. But just to make clear, i meant the threads the screw
into
the intake manifold, not the hoses that connect to the fitting.
Last Edit: September 18, 2021, 05:42:55 pm by Stewart G Griffin
JohnnyPopper
Old Goof
September 28, 2021, 04:30:56 pm »
I use pipe tape on those threads.
1980 C-10 under construction
Shifty
I bleed Bowtie red...
September 28, 2021, 05:21:56 pm »
Quote from: JohnnyPopper on September 28, 2021, 04:30:56 pm
Liquid version of the same thing for me.
98 C2500 ext cab longbed
September 28, 2021, 05:49:58 pm »
So let's rephrase the question like this: Should thread sealant be used on pipe threads? Answer = Yes
⌠ŻŻŻŻŻ' [☼===☼]
