Electrical
No Headlights, Taillights, Horn, or Gauges
Topic: No Headlights, Taillights, Horn, or Gauges (Read 4482 times)
4wdmemes
September 30, 2021, 09:54:25 pm »
Hello all, today I started up my 1984 K10 LWB and noticed that I have no headlights, taillights, sidemarkers, interior lights, or horn. Although when I press the brake, the brake lights work, so no burnt bulb. And the turn lamps work when I use the turn signals. Any help is appreciated, 1984 diagrams would especially be helpful.
bd
Re: No Headlights, Taillights, Horn, or Gauges
October 01, 2021, 10:56:47 am »
The
1984 Wiring Manual
is available along with all the other manuals in our
Technical Forum
Number 1157 (and the subsequent 2057) bulbs have dual filaments. The brake/turn signal lamps and running lamps employ separate filaments within the bulbs. So bad bulbs remain a possibility until physically verified.
Using an incandescent test light, is the alternator #2 regulator terminal constant 12 volts? Check the fusible links and connections to the starter solenoid 3/8" B+ stud.
Susipfm
New Users
May 29, 2022, 08:55:16 am »
I am having the same issue, I found a cab to frame ground strap broken, ordering a new one to see if that is the problem, I'll keep you posted
Sent from my SM-A125U1 using Tapatalk
Electrical
