Author Topic: Rear main replacement method.  (Read 5278 times)
Offline 1987_Rabbit_Hole
« on: January 12, 2022, 01:36:23 pm »
Hey guys
I have an 87 V10 with a leaky rear main seal I’m going to replace.  My question to you guys is if you had the resources to do it either way, would you pull the engine or do it under the truck?  I don’t have a lift.  I have a couple of floor jacks l, some stands and a cherry picker.  Seems to me by the time I wrangle the tranny and xfer case around enough to get in there and then hook it all back up, I could’ve just as easily pulled the motor and done it.  What’s your thoughts?
« Last Edit: January 12, 2022, 01:46:38 pm by 1987_Rabbit_Hole »
Offline JohnnyPopper
  • Old Goof
Re: Rear main replacement method.
« Reply #1 on: January 12, 2022, 04:58:06 pm »
Ugly either way, but with your setup, I would pull the engine.
1980 C-10 under construction
Offline Shifty
  • I bleed Bowtie red...
« Reply #2 on: January 13, 2022, 08:05:09 am »
As Johnny said, tug the motor.
98 C2500 ext cab longbed
« Reply #3 on: January 13, 2022, 08:39:48 am »
Yeah I'm seriously leaning towards that method.  Plus, it'll give me an opportunity to clean it up a bit.  If it was a 2wd I might do it in the truck.
  • Old Goof
« Reply #4 on: January 13, 2022, 01:08:38 pm »
Yes 2WD is a no brainer, but xfer case and tranny are brutal especially if you don't have a lift.
« Reply #5 on: January 13, 2022, 04:18:13 pm »
A) Be 100% positive it is the rear main.
B) Determine why it is leaking, make sure the PCV and breather are functioning correctly.
C) If the seal is crisp it probably wore a significant groove in the crankshaft so you may need to purchase a speedy sleeve kit.
D) If you are pulling the engine, that's the best time to reseal everything and give it a tune-up.
  • Old Goof
« Reply #6 on: January 13, 2022, 08:22:45 pm »
Good stuff VZ,
I recently bought a seal for my timing chain.
The harmonic damper had a groove, but the seal was designed to be offset so I didn't need a speedy sleeve.
« Reply #7 on: January 14, 2022, 06:35:41 am »
Good advice.  Thanks.  Already done valve cover gaskets, pan gasket, and inspected around the distributor/intake area, and completely replaced the PCV system and verified flow.  I've eliminated all possibilities but the rear main, cam plug, and flywheel bolts.  All of those I've got to remove the trans or engine to see, so I'll know in a day or so.
« Last Edit: January 14, 2022, 06:43:48 am by 1987_Rabbit_Hole »
