Author Topic: 1983 Chevy k10 With 454 Starter issue  (Read 5754 times)
Offline Cdog_1996
« on: January 24, 2022, 08:04:51 pm »
Need help!  I have a 454 out of a 78 suburban in my 83 k10, has started and ran before but my starter is very far out from the flex plate, the Bendix might catch 1/16 of an inch of the flex plate, turns slow, sometimes it doesn't do anything and virtually impossible to get it to crank consistently.  Makes a terrible screeching sound, I've tried a stock style and a mini starter both with the same issue, I can't find a solution for this problem
Offline wz7u
  • Old, tired - like the truck
Re: 1983 Chevy k10 With 454 Starter issue
« Reply #1 on: January 24, 2022, 08:14:55 pm »
Wrong flex plate?
'79 C20 454/th400 "Pearl"
Offline Cdog_1996
« Reply #2 on: January 24, 2022, 08:19:25 pm »
I don't think so, it was attached to a th400 and then pulled I installed it to a built th350, seems original I don't see why or how the flex plate would be wrong and it matches the pads on converter
Offline JohnnyPopper
  • Old Goof
« Reply #3 on: January 24, 2022, 09:11:18 pm »
Try some shims.
1980 C-10 under construction
Offline Shifty
  • I bleed Bowtie red...
« Reply #4 on: January 25, 2022, 07:58:40 am »
Is the bendix fully extending (and at least 12v to the starter)?
98 C2500 ext cab longbed
  • Old Goof
« Reply #5 on: January 25, 2022, 01:07:51 pm »
Is it possible that it's in backward?
Offline Cdog_1996
« Reply #6 on: January 25, 2022, 06:10:35 pm »
We'll boys it looks like my flex plate is on backwards, I thought the motor was never messed with but I was wrong
  • Old Goof
« Reply #7 on: January 25, 2022, 11:20:28 pm »
It happens... ::)
Offline Shifty
« Reply #8 on: January 27, 2022, 08:32:15 am »
Nice spot JohhnyP!  ;)
  • Old Goof
« Reply #9 on: January 27, 2022, 12:35:54 pm »
Thanks Shifty!
My 383 is still on the stand, and when I looked at it I could see how that would really 'shift' things!
I'm sure his TC was pulled out as well.
