Author Topic: 250 I6 to 262(4.3) swap  (Read 6727 times)
Offline Ctrout
« on: April 26, 2023, 11:23:43 am »
Hi guys, i'm sure ill get scolded for doing this wrong as a newbie. but I have a question worth the trouble. Been a long time reader of this sights tech chats, super informative and has helped several times with my 77' Big10 and several friends trucks over the years.
Here's my issue, I have a 78 G10 van w/ a 250-6 (integral head) and 3 on the tree (the van sites aren't as techy as the truck sites) the motor was shot 10 years ago, I threw a 95' 4.3 V6 with 96k in (expecting the perches to match). As I understand it (from the subject: 86 C10 262 to 305 swap) 85'-87' 4.3 perches are the only frame ones I can use for this swap. (BTW, this is only site I found that info on). I guess my question is.......... Is there an after market option or am I destined to a life of junkyard searching in the short term? Are there part number(s) to reference further?
Until I get the motor settled in, I can't jump to the next problem, which is the exhaust manifold and exhaust routing to accommodate the clutch/shift linkage for 3 on the tree.
Thank you in advance, Chuck
Re: 250 I6 to 262(4.3) swap
« Reply #1 on: April 26, 2023, 06:27:51 pm »
I believe the transdapt mounts will do the trick for you
Offline Stewart G Griffin
« Reply #2 on: May 16, 2023, 09:01:20 pm »
Huh.....i never knew these existed!
https://www.hedman.com/product-detail/4671
