Author Topic: Rear end swap  (Read 7921 times)
Offline Aitch
Rear end swap
« on: November 14, 2023, 10:58:04 am »
I want to put a disc rear in my 77 C10 short step side. I found a 85 C10 with disc brakes. Will it fit my 77?
Offline Shifty
  • I bleed Bowtie red...
Re: Rear end swap
« Reply #1 on: November 14, 2023, 12:17:06 pm »
Physically it will, though there will be hydraulic changes you'll need to make to function correctly, as well as some parking brake mods.
98 C2500 ext cab longbed
Re: Rear end swap
« Reply #2 on: November 14, 2023, 01:54:59 pm »
It would be easier to just swap out drums vs disc off the donor.   No C10 ever came with disc from the factory so it would be an aftermarket replacement/update.
1977 will have a 12 bolt vs the 85 with a 10bolt (8.5") and has a different size Yoke so total swap would require a hybrid u-joint.
