Author Topic: Brass Bow Tie  (Read 60545 times)
Offline Mr. Machanic
Brass Bow Tie
« on: December 05, 2023, 07:55:19 pm »
The bow tie was missing before we met.
Kept looking online but again, being the skin-flint, I is, it looked easy enuf to make.
Picked a piece of .010 brass from Hobby Lobby for $4.00.
Made a tracing rub of the frame it was supposed to go into and cut out a pattern.
Before C.A.D. meant computer aided design, C.A.D. meant cardboard aided design and both serve me well. There was enuf material to layout 2 bow ties, so one was used as a prototype to prove out the concept and then the second was made with great care to avoid any kinks or dents.
The biggest time consumer was fitting the bow tie into the frame, because the walls of the frame have draft to facilitate original molding ejection out of the mold.
Once the shape and size was achieved the Starburst was drawn with sharpie marker.
Each wedge section was masking taped off and 600g wet/dry was used to remove any scratches and then very fine scotch Brite softened the sanding marks. Once each wedge section was completed, Flitz polish was used to bring up the shine and to help protect from oxidation until a clear gloss can be shot.
Then 2 sided mounting tape will secure it until a stone hits it...oh well, it was a fun learning experience.
In the photo the pattern is in the middle and prototype on the bottom.
« Last Edit: December 05, 2023, 08:00:51 pm by Mr. Machanic »
1978 Big 10 "Bigg'in"
350/350 auto.
Cordova Brown Scottsdale
Zero pollution krap.
Suck, Squeeze, Bang, Blow
Re: Brass Bow Tie
« Reply #1 on: December 05, 2023, 08:02:13 pm »
Another photo with prototype in place....sorta.
350/350 auto.
Re: Brass Bow Tie
« Reply #2 on: December 05, 2023, 08:06:59 pm »
An in process photo.
Almost forgot..
The pieces were cut out with some very sharp sewing scissors....well, they were sharp...
350/350 auto.
Offline Mr Diesel
  • Aaron
Re: Brass Bow Tie
« Reply #3 on: December 05, 2023, 09:12:55 pm »
I like that.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline JohnnyPopper
  • Old Goof
Re: Brass Bow Tie
« Reply #4 on: December 05, 2023, 11:38:56 pm »
I like for the sake of custom.
Prefer stock app's myself.
1980 C-10 under construction
Offline Shifty
  • I bleed Bowtie red...
Re: Brass Bow Tie
« Reply #5 on: December 07, 2023, 11:56:34 pm »
Looks nice!
98 C2500 ext cab longbed
Re: Brass Bow Tie
« Reply #6 on: December 08, 2023, 11:32:04 am »
It presents a nice custom touch.
  • Old Goof
Re: Brass Bow Tie
« Reply #7 on: December 08, 2023, 02:37:16 pm »
Looks like you have the deluxe grill with the extra trim to close up the horizontal gaps. Consider blacking out the faded paint for a refresh.
You could use silver wheel paint and clear coat on the plastic section and boom, instant beauty!
Jones'n for that trim, wonder if it's still available...
« Last Edit: December 08, 2023, 05:27:40 pm by JohnnyPopper »
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Brass Bow Tie
« Reply #8 on: July 26, 2024, 09:48:15 pm »
That is AWESOME!   That is real hot rodding stuff.   Making what you want when you cannot find it it!   Very NICE!
