Author Topic: tire size  (Read 25735 times)
Offline C10Danny
tire size
« on: January 04, 2024, 12:01:52 pm »
hi, all new guy here I'm doing g a frame up restoration on my 78 Silverado. I'm running 245/40/20 and 275/40/20 was wondering if 245/45/20 and 275/45/20 would give me a better ride. or no significant difference I have slozh tubs so tire room isn't an issue. I just installed Qa1 front crossmember and coil overs and 4link rear with coil overs.
Re: tire size
« Reply #1 on: January 04, 2024, 03:25:19 pm »
Although I have never been a fan of that look going from 40 to 45 is going to give you a little taller sidewall.  I doubt that little difference is going to make the ride quality noticeably better.
Re: tire size
« Reply #2 on: January 05, 2024, 07:32:44 am »
Sidewall difference between the 245mm tire is 3.85" vs 4.34" or  .5"
Sidewall difference between the 275mm tire is 4.33" vs 4.87" or .54"
Considering the new front will equal the old rear sidewall height you can see sidewall isn't playing a huge part here.
If you have the coil-over system do they have adjustments on the shock body?  have you tried adjusting them?
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: tire size
« Reply #3 on: July 23, 2024, 01:33:14 am »
Try the Miata Tire Size Calculator.  been around a long long time.
https://www.miata.net/garage/tirecalc.html
