Author Topic: Cab Leak from wash/rain ?  (Read 29108 times)
Offline Chevynut73
« on: February 13, 2024, 09:41:05 am »
I have a water leak that comes into the cab right/passenger side when i wash her.
Ends up with wet carpet where the passenger's right foot would be.
Pretty sure it's not coming in around the windshield.
Any thoughts?   Have any of y'all had this problem?
Thanks
'73 Chevy C10, 350, TH350, was a long Fleetside, now she's a short Stepper that's under construction (been in the Family since 1972).
Would rather push a CHEVY than drive a Furd
Offline Shifty
  • I bleed Bowtie red...
Re: Cab Leak from wash/rain ?
« Reply #1 on: February 13, 2024, 10:03:47 am »
If you're certain it's not the windshield, next guess would be the vents.
98 C2500 ext cab longbed
Offline kgross401
« Reply #2 on: February 13, 2024, 12:19:01 pm »
I had the same problem on my truck and it was a bad hood latch rubber seal
Offline kgross401
« Reply #3 on: February 13, 2024, 12:48:13 pm »
sorry correction I meant hood hinge seal
« Reply #4 on: February 13, 2024, 08:28:49 pm »
Offline Mike81K10
« Reply #5 on: February 13, 2024, 09:16:39 pm »
My cab was leaking from around the cowl, area where the wiper linkage is located. It was a rusted out and was one of the first things I had to repair in my restoration!
« Reply #6 on: February 14, 2024, 08:48:32 am »
short of pulling the carpet and trim to find the source check the cowl area under the windshield this where the firewall and cowl sheetmetal meet, I have seen many rusted out here.
Best bet is to remove the interior and do a water test to find the source.
Offline Chevynut73
« Reply #7 on: February 19, 2024, 05:29:57 pm »
Thank y'all and they all make good sense.
She has very little rust except surface rust and the right finder where the battery leaked acid onto it (it's been replaced now).
After a little more investigation, I think it might be the heater core leaking!  I hear those can be a pain to replace!
Offline Shifty
« Reply #8 on: February 20, 2024, 08:53:52 am »
Nowhere near as bad on today's soap bubbles.  (no personality cars)
Offline juancano
« Reply #9 on: May 01, 2024, 11:27:48 am »
How did you fix that? Do you remove the cowl vent and add a bunch of sealant? Thanks.
Offline Mike81K10
« Reply #10 on: May 01, 2024, 12:51:52 pm »
To fix my truck, I had to cut out the bad metal and weld in patch panels.
Offline JohnnyPopper
  • Old Goof
« Reply #11 on: May 01, 2024, 06:24:52 pm »
"Wind tunnel cars" They all look the same  ::)
1980 C-10 under construction
