Author Topic: Original AM Radio hacked into Bluetooth+AMP  (Read 63364 times)
Re: Original AM Radio hacked into Bluetooth+AMP
« Reply #15 on: September 04, 2024, 12:51:07 pm »
...As for the light, it could just be that an incandescent bulb would work.
Or, perhaps, reversing voltage polarity across the LED...
Offline alfreema
« Reply #16 on: September 04, 2024, 05:47:24 pm »
Hmmmmm
The configuration was funky, there's one positive with two separate grounds.  I got 12v across a white wire (negative) soldered to the top right post of the power terminal block, and the bottom post where the yellow wire comes in (positive).   I soldered the USB C charger's negative wire to that post and the positive to the bottom post (it checked out on the voltmeter and the charger is working well).
Now that I think back on it, I don't remember seeing a second wire run to the bulb socket -- just the white ground wire.  Maybe I clipped out the positive when I was tearing out the other stuff by mistake and need to rerun a positive?  I didn't really spend any time on the socket because I didn't think I was modifying it in any way.  I'll double check next time I feel like pulling the console apart.  :)
Double hmmmmmm
« Reply #17 on: September 04, 2024, 05:57:54 pm »
You'll never turn the lights on if you don't pay the power bill...   :D
Offline alfreema
« Reply #18 on: September 05, 2024, 07:46:09 am »
LMAO
