Author Topic: 84 Jimmy Build  (Read 234833 times)
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #15 on: July 07, 2024, 03:24:40 pm »
I was on vacation most of last week so I only had a few hours of wrench time today.  Got the passenger rocker and inner kick panel cut out, and found some surprises at the quarter panel.  I may have to make some inner panel patches, but the biggest surprise was how poorly the outer rocker fits.  This company needs some serious QC upgrades.
And here is how bad this fits...
« Last Edit: July 07, 2024, 03:27:11 pm by 1981lt1 »
Offline Shifty
  • I bleed Bowtie red...
Re: 84 Jimmy Build
« Reply #16 on: July 08, 2024, 09:53:54 am »
Wow!  I'm glad it's not me doing that.....I need to keep myself free to do honey-do's.... ::)
98 C2500 ext cab longbed
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #17 on: July 09, 2024, 08:05:56 pm »
Got quite a bit done over the past couple of days.  The floor pan has been fixed, along with the rusted sub structure, and the inner kick panel has been fitted.  Now that i've gotten the front floor pan fixed, I wanted to start fitting the rocker, but I need the door mounted to make sure my reveals are good.  I've learned the hard way to not weld up the rockers until the door is positioned correctly.
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #18 on: July 09, 2024, 08:12:49 pm »
Offline JohnnyPopper
  • Old Goof
Re: 84 Jimmy Build
« Reply #19 on: July 09, 2024, 08:14:34 pm »
Nice work! I would have never volunteered for that much work.
Yeah, extremely poor fitment.
« Last Edit: July 10, 2024, 07:41:42 am by Captkaos »
1980 C-10 under construction
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #20 on: July 09, 2024, 08:24:26 pm »
You are correct!  I've had some fitment issues with their stuff on a previous project but this is pretty bad.  Unfortunately, I've already bought the parts I need so I'm stuck with everything.
  • Old Goof
Re: 84 Jimmy Build
« Reply #21 on: July 09, 2024, 10:58:16 pm »
Well, it looks like you have to skill set to overcome their lack of quality.
Look forward to your continued progress  ;)
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #22 on: July 11, 2024, 08:15:09 pm »
Actually, i'm not afraid to cut things apart and i'm just a very good grinder!  My welding/fabrications skills are novice at best.
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #23 on: July 11, 2024, 08:28:56 pm »
Since I'm still waiting for my new door hinges, and they likely won't be here this week, I started on the rust in the rear of the cab floor.  Of course, it wasn't just the floor pan, it had to be rotten in the support as well.
Offline Shifty
Re: 84 Jimmy Build
« Reply #24 on: July 12, 2024, 10:11:24 am »
That's a ton of ugly to cut off....
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #25 on: July 12, 2024, 08:22:00 pm »
There was so much welding on this section.  I had to make another backing plate and then completely rebuild the bottom of the side panel where it meets the floor.  The combination of my poor welding skills and extremely horrible fitment of the replacement panels equals a crap ton of grinding about the same amount of seam sealer.
Offline Shifty
Re: 84 Jimmy Build
« Reply #26 on: July 13, 2024, 10:32:38 am »
Talk about an opportunity to sharpen your skills...
  • Old Goof
Re: 84 Jimmy Build
« Reply #27 on: July 13, 2024, 06:36:23 pm »
Ton of work! What kind of welder are you using?
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #28 on: July 14, 2024, 04:10:43 pm »
I'm using my 110v MIG welder i've had for many years and hasn't died on me yet.
Offline 1981lt1
Re: 84 Jimmy Build
« Reply #29 on: July 14, 2024, 04:15:11 pm »
spent yesterday and today getting my rocker panel alignment set so I could welded everything up.  Thank God I didn't just eyeball it based on the contours.  Because these panels are such poor quality, you'll notice the fender mount hole at the front of the rocker doesn't match with the inner kick panel hole.  I'll get this fixed when I'm ready to mount the fender so that'll get done later.  I'm a bit irritated at the gap along the bottom of the door but there isn't anything I can do about it without more cutting and bending and I'm simply ready to move on to the quarter panel at this point.
