Author Topic: Fuel Guage  (Read 21518 times)
Offline SILSquarebody
Fuel Guage
« on: August 04, 2024, 08:11:32 pm »
I bought an 86 K5. I am slowly working thru all the problems with it. The gas guage show it is way over full when you start it. Can someone tell me what color the wires are for the fuel guage please? Ground problem? Or what you think?
Online bd
Re: Fuel Guage
« Reply #1 on: August 05, 2024, 10:56:05 am »
1986 Factory Wiring Manual
Functional Tests of Factory GM Electric Gauges
Does the fuel gauge needle point at ~3:00 o'clock position and remain there continuously with the ignition switched ON or does the needle drop normally while driving?
Re: Fuel Guage
« Reply #2 on: August 05, 2024, 04:57:53 pm »
Yes it does stay at 3 o clock.
Online bd
Re: Fuel Guage
« Reply #3 on: August 05, 2024, 05:07:40 pm »
There's an open in the signal circuit from the sender, or the sender rheostat in the fuel tank is open, or the sender isn't properly grounded.  For wire colors and routing, refer to the linked factory wiring manual.
Re: Fuel Guage
« Reply #4 on: August 05, 2024, 06:51:12 pm »
Where do I find the wiring manual?
Re: Fuel Guage
« Reply #5 on: August 05, 2024, 06:55:48 pm »
NVM I found it. Thanks.
