Author Topic: Does anyone know part number for carrier bearing and rubber boot  (Read 25839 times)
Offline plow_truck
  • naturally aspirated
Does anyone know what correct carrier bearing and whether there is an appropriate rubber boot?
I'm in the process of replacing the carrier bearing and it looks to me like there should be some sort of boot to cover the open spline.
The u-joints are spicer 1350 series (1.188 OD x 3.63 end to end) and the carrier bearing is 1.574 at the bearing with a 1.500 dia spline.
Its a 1979 K30 with SM465 transmission and a 454 that was swapped in, also its got 4.56 gears.
I'm going through the dana / spicer catalog and theres a handful of these (carrier bearing) that come up under style 15 with 1.574 ID, 6.62 bolts to mount and 2.25 dim from bottom to bearing center... but they have different front slinger / rear slinger. If those are the pieces on the end, then I want to replace them if I can.
Re: Does anyone know part number for carrier bearing and rubber boot
« Reply #1 on: June 23, 2025, 05:31:37 am »
What auto parts stores are around you?
O'Reilly try 6038
Offline JohnnyPopper
  • Old Goof
« Reply #2 on: June 23, 2025, 10:59:19 pm »
For so much undercarriage rust, the cab seems to be in solid condition!
If the number Vile gave you is a O'Ry number and they don't have one, ask them for the full OEM or aftermarket part number equivalent.
That will be the key to finding it, because they (other parts stores) can then cross reference other brands.
You'll have a list of Brands/Part # to look for, if not local, then on the Internet.
Hope it goes well, we love hearing about it.
1980 C-10 under construction
Offline plow_truck
« Reply #3 on: June 24, 2025, 05:11:06 am »
VileZambonie:
I can certainly give that a try I'm in southern NH and there are plenty of O'Reilly in my area. I'm planning to go there at some point to borrow a bearing puller since that bearing won't come off easily.
That part probably is a good fit, I'd just have to verify the 2.25 dim from base to center.
Do you know if this driveshaft would normally have a rubber boot covering the splines? I wouldn't think that this would be left unprotected but at the same time I'm not sure the joint was designed for this. I tried scouring the internet looking for pictures and driveshaft boots certainly exist but I have no idea if such a thing exists for this configuration.
Anyway the spline is pretty rusty in the couple inches that are exposed and it'll still certainly work fine. Its just that I would be kicking myself if I reassemble and then later realize I left something out.
JohnnyPopper:
The frame is generally solid too. I'm in the process of replacing the cross member. And so I'm going to repaint the frame before the new cross member is installed. Well, I got that started and now I plan to put a coat of paint and new ujoints and bearings on the driveshaft too. Not to mention that I've got to replace the bed as well. I am looking for a flatbed or dump body but don't have a replacement lined up.
Yes, the cab is in pretty good shape. I'm replacing the cab mount bushings too and was pleasantly surprised to find that the weld nuts in the frame are still in tact.
As to getting full OEM part numbers from auto parts stores I'll try that.
Thanks for the comments. I will keep you posted.
« Reply #4 on: June 24, 2025, 06:51:46 am »
Parts manuals are in the tech forum peeps
Offline plow_truck
« Reply #5 on: June 25, 2025, 04:57:04 am »
I didn't realize that was there, thanks for pointing it out. I've got a reprint of the 1979 service manual but that's it.
I don't think that there is a boot designed for this. I think all I can do is apply paint.
Anyway, I made the trip to orielly auto... I brought home 6053 and I'm trying to confirm its the correct before I open it.
The only difference between the 6038 and 6053 are the slingers and they did not have a puller with the length needed to pull the bearing so I'm going to cut the old rear slinger and I'm thinking I'll be able to hammer the old bearing off.
  • Old Goof
« Reply #6 on: June 25, 2025, 01:10:56 pm »
Nice progress.
Have you guys heard/tried "Superzilla" yet?
Been wrenchin for upward of 55 years, NEVER seen anything like this.
Offline plow_truck
« Reply #7 on: June 28, 2025, 06:41:43 am »
So, I didn't see the superzilla at the local hardware store I had to order online. Nope never heard of it before. Anyway I can appreciate the value of good penetrating oil (or just the little things that help a job go smoother) so I will try it out. Its not that I want to be dealing with rusted hardware but I always have a can of penetrating oil in the garage.
Yesterday things worked out in such a way that I got a couple free hours and finally removed the carrier bearing. A little backstory here:
-I tried to hammer the bearing off the shaft but it wasn't happening
-I asked if there was a puller at the auto parts store for loan and they didn't have anything with enough reach
-I brought the shaft section to work since there is a decent work table and vice. I was thinking I could grip the bearing and hammer the shaft out, however I could not fixture it well enough to try this so I gave up and figured I'd cut the bearing off
-I considered the use of heat but didn't feel I would have enough control to prevent damaging (annealing) the shaft
I got home early enough yesterday to have a few minutes to work on cutting the bearing off. Unfortunately for me, I am working on the gravel driveway, I locked a vice grip on the outer race and had weight on that and the driveshaft barrel so I could prevent any movement since any kickback could result in scrapping the driveshaft. Anyway for cutting the outer race I used an electric angle grinder with a 4" cutoff wheel. I made two cuts and split the outer race, then I removed all the other stuff, the cage, the balls and the ancillary guards. After this I carefully cut into the inner race with a cutoff wheel on a dremel. I worked on this for a good few minutes basically carving it up and making sure never to cut through. I made one cut that was in the axial direction almost through. Next I made a little notch at about 90 degrees, just enough to hold a chisel point. Then I stood the shaft on a wooden block on the spline end and held a chisel in the notch and hammered the race off. My cut was deep enough that it basically popped right off.
The above is probably not the best way to accomplish a bearing removal but my guess is its probably not all that uncommon either. Its fine by me if you chime in about better methods I'm not really defensive about this kind of thing. If there's a better way I'd like to know, but at the same time I did research and all I was coming up with were more tools I could buy and honestly my garage is pretty tight so I really try to avoid buying specialty tools.
I think the shaft looks OK. I'm sad that the exposed (splined) area between the end of the yoke and the carrier bearing is so rusted, but I think its mechanically solid and will transmit power just fine. The rust on the driveshaft body (tube) is pretty intense too, but its cleaning up well and I'm going to paint it and keep it all in service.
This project is a bit more than I wanted to get into and it probably goes without saying that I'm not a very experienced vehicle mechanic, but at the same time I find that with a little research I can get good results. Once everything is back together the next question is whether I'll have a balanced system. If I experience symptoms of imbalance I guess the plan is to take the truck to a driveshaft shop, but I hope it doesn't come to that.
With that said, whats the best way for a shade tree mechanic to test balance? I certainly can't put a dial indicator on it and drive down the road, I would be able to see the dial!
« Last Edit: June 28, 2025, 08:48:35 am by bd »
« Reply #8 on: June 28, 2025, 07:02:27 am »
Not sure what we're looking at with that picture. You should contact a driveshaft shop in your area to balance it or go to a one piece driveshaft and be done with the carrier bearing altogether.
Offline plow_truck
« Reply #9 on: June 28, 2025, 07:51:34 am »
ok, yeah the picture is messed up. something happened when I rescaled it.
A one piece driveshaft?! I'll call the shop about that. That has a lot of appeal to me.
