Author Topic: Quadrajet Replacement  (Read 42665 times)
Offline Rapid Roy
  • Euless, Texas
« on: July 08, 2025, 12:27:25 pm »
Planning to replace the Carter Q-jet soon. Wanting to replace with new. Have not purchased new before, only had rebuild. Is there anything special needed to be done prior to install?
TIA
Mopar by Birth
Chevy by Choice
Re: Quadrajet Replacement
« Reply #1 on: July 09, 2025, 08:42:00 am »
where are you planning on getting a "new" Q-Jet?  Edelbrock stopped making them a while back.
Offline Rapid Roy
  • Euless, Texas
« Reply #2 on: July 09, 2025, 10:38:51 am »
Not sure. Have seen some online stated as new, not re manufactured but not sure. Not specified as Edelbrock or any other brand.
Mopar by Birth
Chevy by Choice
« Reply #3 on: July 09, 2025, 07:10:57 pm »
Temu  ;D
Offline philo_beddoe
  • 77 C-10
« Reply #4 on: July 11, 2025, 08:44:25 am »
I bought a QJ/Rochester from National Carb. VZ installed and tuned it (with a new engine), haven't touched it since, going on like 8 or 9 years. Gripe! ....has it been that long?!
https://nationalcarburetors.com/
Offline JohnnyPopper
  • Old Goof
« Reply #5 on: July 11, 2025, 02:14:23 pm »
I bought two from National, one for my daily and one for a project.
Daily wouldn't adjust on idle screws, turned in completely and the engine still ran.
Sent it back and they fixed it at no cost, even thought just out of warranty.
Replaced the throttle body and some other items.
If they don't have a carb to match what you have, they will rebuild yours. Good outfit!!
1980 C-10 under construction
Offline zucchi
    • Driving my old car forever video channel
« Reply #6 on: September 10, 2025, 11:19:04 am »
I acknowledge this topic is two-months old, nevertheless, I'd like to put in my two-cents.
The first question I always ask is, "Is something wrong with the carb you have?" Like the old saying, if it ain't broke, don't fix it.
Unless your QJ is physically damaged beyond repair, e.g., hit with a mallet, it’s best to stick with it. Your car’s linkage, fittings, intake, choke, etc., are all designed to work in harmony with the QJ. Furthermore, as already mentioned, the carb that came with your truck is calibrated for your truck.
Why pay some inept wrench turner to break something, then claim it was that way when I brought it in, when I can break it myself for free and learn something along the way.
  • Old Goof
« Reply #7 on: September 13, 2025, 12:33:58 am »
Good question. Thanks!
I have an older GM car, with a QJet, no smog requirement. I paid a smog tech a C-note to sniff the Carbon excess, and adjust it down. It smells alot better...
It's been stated on other threads that these carbs are the best and the worst... you decide  8)
« Reply #8 on: September 16, 2025, 09:58:20 am »
Quadrajets were designed for these trucks and calibrated when they were new, but saying they are still calibrated after 35+ years and 100K miles, not so much.  Anything still running today would need adjustments especially if the motor is original.  Personally I much prefer Quadrajets, second only to EFI.
Offline zucchi
« Reply #9 on: September 16, 2025, 10:32:19 am »
…saying they are still calibrated after 35+ years…
The rule of thumb is anything that can be adjusted can fall out of adjustment. That's why tune ups are done at regular intervals. Worn parts are replaced and adjustments are administered to bring instrument readings back into spec.
