Author Topic: What Transmission do I have?  (Read 25525 times)
Offline JohnnyPopper
  • Old Goof
« on: November 04, 2025, 07:48:45 pm »
I bought a TH400 from my buddy who has a truck recycling gig here. He said he drove the truck prior to parting it out, checked out.
I noticed when looking at it, that it had a 6 bolt TC. I noticed that all the Flex plates I worked with have 6 mounting holes, but only ever used 3.
Any clue on what this came out of? Are there better features than a standard TH400?
TIA
1980 C-10 under construction
  • Old Goof
Re: What Transmission do I have?
« Reply #1 on: November 05, 2025, 07:39:27 pm »
Chat GPT is your friend.
Given your description (BBC engine + converter with 6 attachment pads + TH400 mention) I believe:
You probably have a heavy‐duty or aftermarket converter that uses a 6-bolt pad layout (possibly built for a TH400 or a TH400‐derived/4L80E application).
It is not a typical factory TH400 behind a BBC but rather an upgraded/modified unit.
The flexplate or converter may have been adapted/swapped for performance/drag use, hence the 6-bolt mounting.
Offline Mr Diesel
  • Aaron
« Reply #2 on: November 06, 2025, 06:26:04 pm »
The 6 bolt TC were used on the 6.2 diesel. Supposedly heavier duty. Heard very mixed opinions about that though. Not sure if they had other applications too.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
  • Old Goof
« Reply #3 on: November 07, 2025, 02:40:31 pm »
That makes a lot of sense, Thanks!
It has a deeper pan as well.
Were the 'mixed opinions' about the trans or the application?
Offline Mr Diesel
  • Aaron
« Reply #4 on: November 07, 2025, 03:42:51 pm »
Mixed opinions about whether the 6 bolt was better or different internally.
The 400 is a great transmission.
