Author Topic: TCC lockup pin location  (Read 25481 times)
Offline frotosride
    • WFO CONCEPTS
« on: June 10, 2026, 10:18:25 am »
Looking for where the torque converter lockup (+) purple wire pins in at the firewall. Honestly can't remember if it is a separate plug/connection or if it was originally on the main bulkhead for the fuse panel. It's been so long that I can't remember where I de-pinned it from.
1987 V10 Silverado 700r4
Online bd
Re: TCC lockup pin location
« Reply #1 on: June 10, 2026, 12:53:04 pm »
The purple wire (Ckt 420) supplies I+ to the TCC solenoid from the brake switch.  It routes through the firewall bulkhead connector as shown.  Is this the wire you are questioning?
Offline frotosride
    • WFO CONCEPTS
« Reply #2 on: June 12, 2026, 07:48:37 pm »
Thank you, I swear I looked through all of the diagrams listed for '87 but couldn't find this diagram. The ones listed/pinned say 1987 but are printed for 1988 and have more pins. I almost just put it back together where ever I had a free spot. But I stopped so I can do body mounts. I did find #420 on the other chassis diagrams but the bulkhead connectors didn't look right.
Did you pull this sketch from the ones pined above?
« Last Edit: June 12, 2026, 07:57:19 pm by frotosride »
Offline frotosride
    • WFO CONCEPTS
« Reply #3 on: June 12, 2026, 07:54:48 pm »
I have kept the brake switch without vacuum hooked up. I'm letting the Terminator handle (-) control for the relay and the brake switch (+) for tcc lockup. Also plan to use the 4th gear grounding circuit as input for possible future tuning configs.  Thanks again
Online bd
« Reply #4 on: June 12, 2026, 08:59:47 pm »
I compiled the diagram from two separate diagrams illustrated in the '87 factory wiring manual.  It took a minute because there are circuit omissions in the diagrams that obstruct easy correlation.  You're welcome!
Offline frotosride
    • WFO CONCEPTS
« Reply #5 on: June 15, 2026, 07:32:19 am »
Oh, you read the big words... That's not my style, I prefer pop-ups. But seriously thanks and now I have to find it!
« Reply #6 on: June 17, 2026, 10:03:06 am »
Terminator as in Holley?
Offline frotosride
    • WFO CONCEPTS
« Reply #7 on: June 21, 2026, 11:49:59 am »
Yes sir
Online VileZambonie
« Reply #8 on: June 23, 2026, 04:54:26 pm »
As in Arnold
« Reply #9 on: June 29, 2026, 03:45:53 pm »
As in Arnold
Funny Vile  ;D
Curious are you using (assuming) Terminator (not X Max) and you are wanting to lockup the converter on the 700R4?
Offline frotosride
    • WFO CONCEPTS
« Reply #10 on: July 10, 2026, 01:32:15 pm »
Sorry been busy, my daily decided that power steering doesn't belong in the hydroboost anymore and while running the engine to prime the system the water pump decided to stop weeping and flood the driveway.
Anyway, yes I allowing the Terminator (not the x, but technically they are the same you just have to download a config and build a harness) to control the lockup via the (-) switching power for a relay. I'm doing this because within the config you can set many parameters and add inputs as needed to edit triggers. Also I can use TPS and not run another vacuum hose through the firewall. Having a vintage air set up helps that too
« Reply #11 on: July 11, 2026, 01:13:50 pm »
cool thanks for the feedback.  The X vs X max are much different however: the X Max will do Drive By Wire and Automatic trans control
Offline frotosride
    • WFO CONCEPTS
« Reply #12 on: August 11, 2026, 11:11:12 pm »
I have yet to prove my theory but from my poking around it seems as though the drivers are in both boxes. I haven't verified the pins but the x has plenty that aren't used.The major one that the x absolutely might not have is likely drivers for DBW. I'm currently using a 4l60e config for my 700 so I can use the VSS signal for special functions. Maybe one day I'll test this out by pulling a config from the global and seeing if the pins work. Wouldn't be the first time a manufacturer made something exactly the same but marketed different.
« Reply #13 on: August 13, 2026, 04:58:34 pm »
I am using a Terminator X Max on my daughters 2011 Mustang that I LS swapped with a 4L60E, I ran out of I/O fast, it only comes with 4 fully programmable inputs and 4 fully programmable outputs.
Offline frotosride
    • WFO CONCEPTS
« Reply #14 on: August 26, 2026, 04:23:06 pm »
Yes, the outputs are definitely the things I'd want more on for the basic unit. They do have an I/O expansions that simply plugs in and uses can bus just like the everything else. I just decided to limit myself and not spend the money. At least that'll be one more slightly reliable Trashstang on the road.
