Author Topic: Motor mount brackets wrong?  (Read 7849 times)
Offline JaredD
« on: June 27, 2026, 11:35:57 pm »
I am installing a sbc in a 83 C10 and I noticed the top clamshell tabs appear to not rest on the supports since the motor mount brackets flair at the top; does this look correct?  On one side the tab is barely under the bracket but as you can see the other is within it.  I bought the motor mount brackets off of eBay but I’m wondering if I got the wrong parts?  See part number in pic below.
« Last Edit: June 29, 2026, 10:11:29 am by Captkaos »
Re: Motor mount brackets wrong?
« Reply #1 on: June 28, 2026, 02:44:44 pm »
Well the mounts look odd... This is what you should be using
