Can you open them up and find the points of failure? Multiple pumps doing this points to a likely problem elsewhere, unless you can pinpoint the reason for failure. Last one that failed on me was a plastic pivot piece inside. China part. Replaced it with a Carter that was metal components instead. A carburetor requires very little pump pressure so your failure inside the pump should be pretty obvious.
