Author Topic: Rear Signaling  (Read 617 times)
Offline JohnnyPopper
  • Old Goof
Rear Signaling
« on: November 17, 2026, 08:36:06 pm »
Seems my rear tail lights are dim, and when the running lights are on, both sides show a blinking to a degree. the selected direction is brighter, while the opposite direction has a dim flash.
Not so much when the running lights are off.
Pretty sure it's a grounding issue. I'm going to show AI a pic of the connection to the bed. (K10 short side step) and see what it says.
Sad to see this vibrant site go cold for the last few years.
FYI, I bought 'Cherry Bomb' to flip 10 years ago...
1980 C-10 under construction- GONE!
Offline bd
Re: Rear Signaling
« Reply #1 on: November 17, 2026, 09:23:21 pm »
Just to be clear, you're discussing the REAR taillights?   ;D
That's a   s l o o w w   m o t i o n   f l i i i p p .   They say time flies when you're having fun.  Now you know it's true!!   8)
Must be truck love...   :-*
You're probably right about a grounding issue (body & frame to battery).  Could be a supply issue in the B+ lead feeding the lamp control circuits too.
  • Old Goof
Re: Rear Signaling
« Reply #2 on: November 24, 2026, 07:33:40 pm »
Yes, rear lights.
You nailed it bd! This truck was new when I turned 18.
The deeper I got into it, the more it took on meaning. The last thing that started out as a vision, the 2.5" lift, and 35's on stock rally wheels really brought it home. I have since added CARR steps to the rockers.
And with the value of these Square's ticking up, I won't be losing any $.
« Last Edit: November 24, 2026, 07:39:14 pm by JohnnyPopper »
