Author Topic: Who makes the best locking hubs?  (Read 16011 times)
Offline Kevin108
« on: August 12, 2002, 06:29:00 pm »
Looking for opinions on who makes the best hubs.
ProComps are $73.
Warn Premiums are $90.
SuperWinches are $92.
87 Silverado 4x4 Longbed Pickup
My Mods | Truck Pics | E-mail Me
Offline 79GMC4x4
Re: Who makes the best locking hubs?
« Reply #1 on: August 20, 2002, 12:03:00 pm »
All of them are good, and don't forget Milemarker.  Most people would tell you Warn, since they are the most heard of and started locking hubs, but they all work.
'79 GMC shortbed 454 th400 14 bolt FF NP205 Dana 60
Offline 73K20
« Reply #2 on: August 20, 2002, 03:55:00 pm »
Warn is the only one that would get my money.
1973 K20 - 350/350/205
Offline mnz28
« Reply #3 on: December 27, 2009, 09:31:18 pm »
Anything need to be done to the transfer case when switching from auto to manual hubs?
« Reply #4 on: December 28, 2009, 02:04:16 am »
i have warn on my truck and they seam to hold up too good keep breaking axle shafts cause the hubs wont break. nothing has to be done to the t case just swap them over and all is well
Offline Josh454
« Reply #5 on: December 30, 2009, 09:33:57 pm »
I would vote Warn the best, Superwinch the worst...
Offline Chevalade
« Reply #6 on: December 30, 2009, 11:27:54 pm »
Stock spicers are the best there is period. Then warn premiums.
Offline captain carnage
« Reply #7 on: January 01, 2010, 07:24:31 pm »
In my years of heavy rat bagging in my truck, I've ran spicers and a few different sets of warns, and only ever broke one warn.
Offline dblxx
« Reply #8 on: January 03, 2010, 10:54:03 pm »
 I have broken 2 Warn hubs, both times Warn replaced them free of charge even after I explained it was my fault both times.
Offline 1980c10
« Reply #9 on: January 04, 2010, 08:12:02 pm »
warn is the all i've ever had and never had a problem.
« Reply #10 on: January 04, 2010, 10:20:36 pm »
I have had about every brand out there. Have broken a few Warns, and Spicers. I have a pair of Selectro hubs on my 86. Have failed to break them yet. When I take them apart everything comes apart nicely, they alway look good inside. The inner ring is held by a snap ring too, not one phillips screw. They are 3/4 turn hubs though.
Offline scpscpscp
« Reply #11 on: January 11, 2010, 07:51:53 pm »
My vote is for Warn.  I did not have ANY luck with MileMarker, had 2 different sets break.  Broke the original set from PO and replace with another set.  Broke those and went to Warn.  No more problems.  My 2 cents worth.
« Reply #12 on: January 12, 2010, 02:17:26 am »
just something else to think about, your hubs are supposed to break first before your break your axle shaft or anything else like i said before i have done broke 2 axle shafts and the same warn hub has to be taken off to replace them, imo i might be stepping it down lol
Offline Engineer
« Reply #13 on: January 18, 2010, 08:25:48 pm »
I have the O.E. Spicer lockouts on my Dana60.
I would try to find a set to fit your '87. GM offered them up to 1980 when they themselves started using Warn, and the auto lockers.
Spicer lockouts for a D60 are dern neared impossible to find, but because they use all steel gears, they are dern neared impossible to break.
The 1/2~3/4 ton Spicer lockouts are pretty common though. Should be able to score a set off of ebay or a local salvage yard that has some of the older iron.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
