Author Topic: putting a turbo 350 in saread of a 4 speed  (Read 7055 times)
sandmechnaicyahoocom
  • Guest
« on: October 28, 2002, 08:16:00 am »
I am looking at removing the granny 4 speed from my 74 k20 and putting in a turbo 350, i already have one with the 4 wheel drive shaft and adapter, but I read that the 205 t-case has different splines depending on the application, I was wondering if any one has tried this yet and how it worked, any help or suggestions would be greatly appreciated thanks RJ
Offline 73K20
Re: putting a turbo 350 in saread of a 4 speed
« Reply #1 on: October 28, 2002, 11:35:00 am »
The SM465 has a 10 spline output shaft and the TH350 has a 27 spline output shaft.  You need to get a different t-case.  If you can get one from behind another TH350 it will of course hook up, but also be on the lookout for a t-case from a 700R4 because they had the same output shaft as the TH350.
1973 K20 - 350/350/205
Offline Kevin108
« Reply #2 on: October 29, 2002, 08:15:00 pm »
Also aren't the output shafts different between 2WD and 4WD?
<b>87 Silverado 4x4 Longbed Pickup</b><br>
<a href="http://www.pavementsucks.com/gallery/viewride.cgi?ride_id=355" target="_blank">My Mods</a><font color=#ffff00><b> | </b></font><a href="http://community.webshots.com/album/39000270gLAeZe" target="_blank">Truck
Pics</a><font color=#ffff00><b> | </b></font><a href="mailto:kevin108@pavementsucks.com">E-mail Me</a><br><b>Maker of 43 point turns!</b>
