Author Topic: Rear End ?'s  (Read 7502 times)
Offline stss95
Rear End ?'s
« on: August 04, 2003, 01:18:00 am »
I need a new rear end for my 85 chevy half ton. Its a 4x4 with 3.73 gears. I was wondering what year trucks (blazers, suburbans) I can get a rear end out of and bolt it right in???
Offline 77 Shortbed
Re: Rear End ?'s
« Reply #1 on: August 05, 2003, 09:13:00 pm »
Somebody correct me if I'm wrong but I believe that any rear axle from a 1/2 or 3/4 ton from 73 on up to 91 or so will fit.
Offline Kevin108
Re: Rear End ?'s
« Reply #2 on: August 10, 2003, 04:27:00 pm »
I dunno about the 3/4-tons, I thought they had the same spring setup as the 1-tons, which is about 3" narrow...  But for $100 any ironworks shop can move your perches and/or shock mounts.
87 Silverado ½-ton 4x4 Longbed Pickup
350 TBI, 700R4 w/ Corvette servo
4" Skyjacker, 33x12.50s
14-bolt rear & Detroit coming soon
My Mods | Truck Pics
Offline 73K20
Re: Rear End ?'s
« Reply #3 on: August 11, 2003, 09:47:00 am »
1/2 and 3/4 ton trucks have the same spring perch locations.  1 tons are narrower to accomdate dual rears.
1973 K20 - 350/350/205
Offline 79SilveradoK30
single-wheel 1-ton
« Reply #4 on: August 11, 2003, 11:50:00 am »
What about 1-tons without the dually rear? I was under the impression the single-wheel and dual-wheel 1-tons had different sized (width-wise) rearends.
Offline 73K20
Re: single-wheel 1-ton
« Reply #5 on: August 11, 2003, 02:57:00 pm »
Nope.  The reason that single and dual rear wheel 1 tons use the same spring perch locations is that the frames on all 1 tons are the same.  More specifically, 1 tons all utilize the same rear spring hangers, which are different than those used on 1/2 and 3/4 tons.
