Author Topic: transfer case  (Read 6418 times)
Offline ammmotroop
transfer case
« on: December 22, 2003, 11:09:00 pm »
I have a 85 K10. What type of transfer case should i have . It is 350 Auto. Also it is starting to leakso i think it needs a rebuild or something along those lines. How much is a fair price from a tranny shop for that type of work.
Offline 73K20
Re: transfer case
« Reply #1 on: December 23, 2003, 06:31:00 am »
I would say that you should have a NP 208 which is an aluminum cased chain drive t-case.  I would estimate a rebuild of it to be around $800.  I doubt however that you need a rebuild of it, probably just a seal and gasket kit.
1973 K20 - 350/465(as of 10-04-03)/205
Offline Txstruck
Re: transfer case
« Reply #2 on: December 24, 2003, 05:35:00 pm »
Are you serious? $800!!! :eek  :eek   Where are you getting your info?
PART NUMBER
PER UNIT
DESCRIPTION
TYPE
YEARS
COST
K203000 1
Rebuilder Kit - Bearings, Gaskets, Small Parts and Seals   1973-79
$227.67 see the kit
K203900 1
Overhaul Kit - Gaskets, O'Rings and Seals   1973-79
$56.26
201203 1
Adapter to Case Gasket Except Ford 1973-79
$2.24
201203F 1
Adapter to Transfer Case Gasket Ford 1973-79
$2.62
201203A 1
Input Bearing Retainer Gasket All 1973-79
$.96
301236 1
Power Take-Off Cover Gasket All 1973-79
$1.98
201052 2
GM Adapter Seal with Automatic 2.000 X 2.623 Various
$6.00
201023 2
GM Adapter Seal with Standard (Not in Kit) 1.375 X 2.250 Various
$7.36
201032 1
Input Gear Seal - Double-Lip 1.938 X 2.686 Various
$6.80
201050 2
Input Gear Seal - Use Back to Back 1.938 X 2.686 Various
$3.60
201057 1
Front Output Shaft Seal 1.750 X 3.061 Various
$12.00
201027 2
Ford F & R Output Shaft Seal 1.875 X 3.061 Various
$6.00
201059 1
Rear Output Shaft Seal 2.125 X 2.750 Various
$6.50
301515 1
Inputshaft Ball Bearing   1973-79
$24.64
301523 1
Front Output Shaft Ball Bearing   1973-79
$19.34
301515 1
Mainshaft Ball Bearing   1973-79
$24.64
301523 1
Rear Output Shaft Ball Bearing   1973-79
$19.34
201901 1
Oil Pump Gear 5 teeth - 38 spline - 1/2" wide White Nylon 1973-79
$18.94
201403 1
Small Parts Kit Included in K203000 1973-79
$83.23
203888 1
Drive Chain 2.5" Wide - 49 Links 1973-78
$199.59
203888A 1
Drive Chain 2.0" Wide - 36 Links 1978-79
$155.75
ALT-501   Part Time conversion kit no front wheel hubs (light duty) 1/2, 3/4 & 1 ton Ford, GM & Dodge 1975-79
$74.00
ALT-502   Part Time conversion kit with front wheel hubs (light duty) Ford, GM & Dodge 1/2 ton 1975-79
$176.00
ALT-95.92203/402   Part Time conversion kit with front wheel hubs (heavy duty) GM & Ford 1975-79
$449.00
ALT-75.32203/402   Part Time conversion kit with front wheel hubs (heavy duty) Dodge 1975-79
$449.00
P.S. Here is the URL if you wanna check them out.
www.drivetrain.com
Edited by: Txstruck at: 12/24/03 5:36 pm
Offline 77bowtie
Re: transfer case
« Reply #3 on: December 30, 2003, 07:51:00 am »
I must of missed where the labor charge for the rebuild is listed. Thats gotta make the prices higher.
Offline Txstruck
Re: transfer case
« Reply #4 on: January 02, 2004, 09:55:00 am »
Wouldnt worry about the labor costs. They are to easy to rebuild.
