Author Topic: what size tires can i put on...  (Read 6729 times)
Offline 784x4ron
« on: October 06, 2005, 09:50:00 pm »
i have a 1978 chevy k10 3/4 ton 4x4 i,m putting a 3" body lift on it.can any one tell me what are the biggest 15"tires i can put on it with out cutting the finders down. i would like too put 35x12.5x15..it,s still stock and i have 33x11.5x15" on it now.  thank you...
Offline roundedline
Re: what size tires can i put on...
« Reply #1 on: October 07, 2005, 10:53:00 am »
You need 4" of lift to clear 35x12.5's without rubbing.  Technically you shouldn't be able to clear 33's on a stock truck.  Have the fenders been clearanced?
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline 79GMC4x4
« Reply #2 on: November 02, 2005, 12:13:00 pm »
I currently have a 79 3/4 Ton 4x4.  It is stock and it also clears 33's.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #3 on: November 02, 2005, 05:44:00 pm »
Ensure your rear axle ratio can handle that size tire.  If it is a high gear rear, you may want to lower your ratio.  Large tires make a big difference in rear end ratios.
SgtDel
Offline 1976Scottsdale
« Reply #4 on: November 02, 2005, 09:10:00 pm »
Yes, that is true.  I have 3.08 posi's in my 78k10 and that poor thing will barely go up a hill and hold speed with the 33's on it.  3.42 will do fine, 3.73's are better, but 4.10's are... dare I say it, God-like.  Hope gas milage is of no consequence.
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
« Reply #5 on: November 03, 2005, 11:22:00 am »
I have a 91 sub w/ 33's on her.  The rear is a 3:73, which, with those larger tires,  translates to close to a normal set up 3:08 rear, when you look at the rpm's.
SgtDel
Offline DieselTech
« Reply #6 on: November 14, 2005, 06:34:00 pm »
My 78 has 38.5"s on it with 4.88 gears. A little too low sometimes, but with 3.73's it was a total dog. It now gets up to speed like it should, but runs around 3200 Rpm's at about 65 mph. Gas mileage is terrible! Big trucks drink the gas!
