Author Topic: NP203 speedometer leak  (Read 10768 times)
Offline Destro
« on: January 24, 2007, 12:36:00 am »
Transfer case is leaking at where the speedometer hooks up.
I cant find anywhere that sells the seal or the whole speedometer piece. Does anyone know where to get these parts or a trick to seal it up? Has this happened to anyone else?? I guess GM discontinued the part and all the chain stores don't have a listing.
Offline smier71
Re: NP203 speedometer leak
« Reply #1 on: April 29, 2007, 03:22:19 pm »
i have the same problem. a few years ago i was able to find the speedo cable at carquest for about $7.00. they may have what you are looking for.
Offline joesgarage71
  • Wrench
« Reply #2 on: April 30, 2007, 10:42:22 am »
 Did you replace the O-ring? Should be able get it anywhere.
 Steve
Offline lt1kicker
« Reply #3 on: May 17, 2007, 08:41:41 pm »
So the speedo plugs into the transfer case?  I have an inop speedo as well.  It seems fine in the cluster so I would imagine the cable is bad.
Aj
1979 Chevrolet Scottdale 4x4, 350, 180k
1994 Caprice 9C1, LT1, G80
1995 Caprice 9C1, LT1, FOM9C1
www.fallenofficermemorial9c1.org
