Author Topic: t"stat" module?  (Read 15904 times)
Offline markzepp820
t"stat" module?
« on: March 09, 2006, 09:34:00 pm »
What is this little block box under my dash with multiple wires coming off of it for? Its labeled t"stat" module.
Is this for the ignition system?
Re: t"stat" module?
« Reply #1 on: March 10, 2006, 05:09:00 am »
Could you be a little more specific? Where is it located under the dash and what is your truck? How about a pic?
Offline markzepp820
module
« Reply #2 on: March 11, 2006, 09:14:00 am »
79' C20, Under dash, close to steering shaft.
Offline DnStClr
Re: module
« Reply #3 on: March 11, 2006, 11:24:00 am »
Is it between the column and the parking brake, or on the other side of the column?
DONT cut any wires until we help ya figure it out..:rollin
I'm just kiddin-
It might be the bus bar ground if it's on the left side.
Don
87 Chevy Silverado
Offline markzepp820
right side
« Reply #4 on: March 11, 2006, 07:28:00 pm »
its on the right side of column. looks like a little ignition box or something. It says (T"stat") module on it. I'm guessing the (T) stands for Thermostat. Just curious of what it might be. Any help is appreciated, thanks, Mark
