73-87 Chevy & GMC Trucks
HEI Vacuum Advance Adjustment
Topic: HEI Vacuum Advance Adjustment (Read 12768 times)
SUX2BU99
May 13, 2006, 01:18:00 pm »
Do all HEIs, including stock, have an adjustment inside the vacuum advance canister? I'm talking where you take the hose off the nipple and then insert an allen wrench inside the nipple to adjust timing. Am I correct about this? I'd like to get some more oomph out of my truck and maybe this could be it. What way should I turn it? Do I need a really long wrench? I have a set of wrenches but they don't appear long enough to touch anything inside.
Thanks!
85 SWB FS mild 350 2wd TH350
Re: HEI Vacuum Advance Adjustment
May 13, 2006, 02:07:00 pm »
No
⌠ŻŻŻŻŻ' [☼===☼]
May 13, 2006, 02:10:00 pm »
Grrr. I hate EZboard. No that's not how it works. I think you are thinking of the vacuum modulator on the trans. If you want more oomph, try a tune up and advancing the timing curve a little bit.
⌠ŻŻŻŻŻ' [☼===☼]
86wrangler
May 13, 2006, 02:20:00 pm »
Many aftermarket vacuum advance canisters have that feature, stock ones dont
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
May 13, 2006, 05:33:00 pm »
I've never heard of an adjusting vacuum advance either. Wow, didn't know they existed. I don't see why you would need it. Just make sure your vacuum line is healthy with good suction. As mentioned earlier, you can bump up your timing a little (advance slightly) for a stronger advance..makes sense, huh.
SgtDel
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
SUX2BU99
Re: > Re: HEI Vacuum Advance Adjustment
May 13, 2006, 06:25:00 pm »
Stock doesn't have it eh? Alrighty. I have turned the distributor counter-clockwise to get some better response out of it. I don't have a timing light so I basically turned it until performance dropped off, then backed it off a bit.
Are the Haynes books useful for these kinds of adjustments? My 350 isn't stock, but has a stock HEI and has an Edelbrock carb. It doesn't downshift like I want it to either. If the RPM's are anywhere past 2000, it won't downshift at WOT. Kinda sucks. And when its warm, it will shift way early at like 3700 RPM too
The motor doesn't really make any power past 4500 and I think starts to valve float at like 5000 but I would like to nail it and not have to manually shift it just to take it to 4500.
May 13, 2006, 11:19:00 pm »
which trans do you have?
⌠ŻŻŻŻŻ' [☼===☼]
Lt.Del
Andy aka:SgtDel
May 14, 2006, 07:59:00 am »
You have a th350 in an 85, if it is the same as my 79, you can adjust the kickdown cable at the throttle cable bracket on the intake. Pull up on the plastic tab, move the cable slightly and push it back down.
If your shift points aren't right, adjust your modulator at your th350.
SgtDel
www.HikerMania.com
SUX2BU99
Re: > Re: > Re: HEI Vacuum Advance Adjustment
May 17, 2006, 03:05:00 pm »
Thanks guys. I'll print this out and add it to my 'to do' list
