Author Topic: need measurements of frame to axle!  (Read 4889 times)
Offline shaved80
« on: September 20, 2006, 02:29:00 pm »
i'm looking for measurements from the middle of the axle to closest edge of each of the bed bolt holes. wierd request i know, but i just want to make sure i make the notch centered :D
Offline 123 pugsy
Re: need measurements of frame to axle!
« Reply #1 on: September 22, 2006, 03:43:00 pm »
I got 25" from center of axle to center of bolt hole behind the axle. I got 50" from center of axle to center of bolt at the most forward hole.
This is a LWB
Pugsy
76 C10 LWB
TPI 350
Offline shaved80
« Reply #2 on: September 23, 2006, 01:44:00 am »
cool thanks, the rear one measure right.  SWB's are 2' shorter right? do you think it'd be about 25" from both?
Offline 123 pugsy
« Reply #3 on: September 23, 2006, 06:26:00 am »
Find the center of your whell tub in your box and mark off a line. This is the axle center. Measure from there.
Pugsy
76 C10 LWB
TPI 350
