Author Topic: Incorrect fuel gage reading??  (Read 4515 times)
Offline akmedic70
« on: October 15, 2006, 08:05:00 am »
I have a '77 K10 4 X 4 Silverrado that has a problem with it's fuel reading.  Both tanks are reading slightly above "E" after filling and will fall as fuel is used..  Anyboby have any suggestions?  I've already replaced the gage itself.  Same problem wiht both gages...   Thanks..
Edited by: akmedic70 at: 10/15/06 7:06 am
Re: Incorrect fuel gage reading??
« Reply #1 on: October 15, 2006, 09:14:00 pm »
Check the wiring and the sending units.
Unplug the sender and ground it at one of the tanks.
Offline akmedic70
« Reply #2 on: October 15, 2006, 11:50:00 pm »
Is this a tempory ground from the sending unit to frame?  Or do you think my sending unit is not grounding which needs to be doing all the time?  Thanks for the help..  Marv
« Reply #3 on: October 16, 2006, 04:45:00 am »
Just pull the wire off at the sending unit and with the key on put it to ground. Grounded it should read empty and unplugged it should go past full. That will at least give you an indication if you are getting a signal back to the gauge through the wire and the switch.
Offline akmedic70
« Reply #4 on: October 16, 2006, 05:52:00 am »
Great!!  Thanks, I'll do just that as soon as I get back off the North Slope of Alaska where I work.  Appreciate all the help!
