Author Topic: help...front fender/core support replacement?  (Read 5250 times)
Offline silverado84
« on: January 16, 2007, 03:46:00 pm »
can someone help me out with the steps to replacing right front fender, bumper bracket, and core support....1984 silverado 4x4.
thanks.
Offline roundedline
Re: help...front fender/core support replacement?
« Reply #1 on: January 16, 2007, 04:04:00 pm »
you are going to have to remove everything front the front of the truck except the fender you aren't going to replace.
Do you want the order of steps or something else?  What year truck?
Remove bumper, grille and trim, hood, fender, inner fender, fan shroud/support, A/C conderser and lines, vapor canister lines, electrical connectors for headlight/signal lights, radiator, unbolt front of fender you are retaining from core support, and inner fender from core support, remove 2 frame bushing and everything should come off.
I would mark the shims and keep them with the areas they came off of also.  Pictures before and during help also.  That way you know where everything goes/came from.  I would also tape tag all wires and lines just in case.
www.73-87chevytrucks.com
www.captkaoscustoms.com
Project Su
Jimmy 2WD Project
Offline silverado84
« Reply #2 on: January 17, 2007, 08:16:00 am »
are there any bolts where the door opens up?
also, should i take the inner fender and outer fender apart from each other before removing?
Offline roundedline
« Reply #3 on: January 17, 2007, 09:56:00 am »
There is one bolt at the door above the hinge that the door must be open to remove and there is one at the bottom under the cab.  I would unbolt the inner fender from the fender and remove them sperately.
Project Su
Jimmy 2WD Project
