Author Topic: Cowl induction hood scoop..  (Read 8191 times)
Offline jseifert
« on: April 26, 2007, 12:59:26 am »
Ok, so I dont feel like spending $400-$500 on a cowl hood.... Lets say I just buy a cowl induction hood scoop... To make it functional, would it be possible to cut the top of the hood and leave the support frame on the under-side??? Or would that hurt the strength of the hood too much??
Re: Cowl induction hood scoop..
« Reply #1 on: April 26, 2007, 06:02:38 am »
If you leave the framework it should be fine. I am not positive but speaking from my auto body experience, the support is at least 85 or more % of the strength.
Offline SUX2BU99
« Reply #2 on: April 27, 2007, 02:22:53 pm »
I was thinking about the same sort of thing recently, albeit more from a ram air point of view. I'd like to have my air cleaner connected to my hood and the scoop above direct air directly to the air cleaner. I figured if a hole was cut right through center of the support web 'X', a ring of sheet metal at least as thick as the support webs would have to be bolted back into place to tie all the webs back together. It would be ring shaped so the air could still flow through the scoop, down through the hood, to the air cleaner. I had an idea too for a plenum that would either be connected to the air cleaner base and mate up to this ring for an airtight seal, or the plenum attached to the ring, which would then seal down to the air cleaner base.
If you were looking to make your cowl induction hood functional only from a point of view or venting underhood air, then just cut some holes in the outerskin of the hood without cutting the webs.
Offline jseifert
« Reply #3 on: May 02, 2007, 02:07:18 am »
I am currently "shopping" my truck in Photoshop... Tryin to do all the modifications that I see in my head... That way I can see what it looks like before I spend the money doing it...
Offline jseifert
« Reply #4 on: May 03, 2007, 05:36:51 am »
Hey Chris.....
Do you not have connections to get a 4" fiberglass cowl hood???
Or at least know a good place to get one...
J. Seifert
« Reply #5 on: May 03, 2007, 04:57:01 pm »
Not Fiberglass.  If I could pick someone up it would be USBody.  I have one of their tilts and I really like it.  Enough to get a second one.
