Author Topic: Template for cutting Doors For a Fulltop Blazer  (Read 13580 times)
« on: May 17, 2007, 05:29:24 pm »
Anyone have the measurements or a template for cutting a door for a fulltop Blazer?
Offline toplessblazer
Re: Template for cutting Doors For a Fulltop Blazer
« Reply #1 on: May 18, 2007, 01:39:35 am »
The lower part is easy you just need to cut the post straight across at the same height as the bottom of the window. The top up by the vent window is the hard part. There is about 4 different angles you need to cut in order to get the factory seal to fit once you made the cuts. I can make a couple patterns for you out of poster board if you want me to. I can also take pics of my bare doors if you would like.
« Reply #2 on: May 19, 2007, 11:17:56 am »
Both would be great.  The ones I have seen the bottom piece is cut above the bottom of the door.
I am trying to get the infor for OPP to make kits for the one piece windows for fulltop Blazers.
« Reply #3 on: May 19, 2007, 07:34:48 pm »
These doors are orignal factory cut 74 doors. Here are a few pics. PM me your address and I will send out the templates when I get them made and labeled.
« Last Edit: May 20, 2007, 12:14:12 am by toplessblazer »
« Reply #4 on: May 19, 2007, 07:35:30 pm »
couple more
« Reply #5 on: May 21, 2007, 03:22:58 pm »
the address I can always be reached at is webmaster@73-87chevytrucks.com
Found this on coloradoK5.
http://coloradok5.com/full-convertible-conversion.shtml
« Last Edit: June 21, 2007, 07:38:53 pm by Captkaos »
« Reply #6 on: June 05, 2007, 04:50:32 pm »
Any update on this?  Did you want my mailing address?  If so it is
Chris Lucas Enterprises
3298 Pike Ave
Birmingham, AL 35224
Offline shaved80
« Reply #7 on: June 05, 2007, 08:02:31 pm »
i saw this post on craigslist not too long ago, don't know if you'd want to deal with buying/shipping and stuff though... http://phoenix.craigslist.org/pts/343396032.html
