Author Topic: c notch question  (Read 8146 times)
Offline bigbubba87
c notch question
« on: May 27, 2007, 08:31:47 pm »
hey guys,
i'm gonna flip the rear of my 87 lb,if i c notch do ya have to remove the bed?
also to solve the shock issue have any of ya run these shock plates?
http://www.speedwaymotors.com/p/3528,154_Lower-Shock-Mounting-Plate.html
Re: c notch question
« Reply #1 on: May 27, 2007, 11:37:27 pm »
I would highly recommend removing the bed.
I use shock extenders for all my flip kits.  What you linked isn't going to help since it won't be low enough in my opinion.
DJM flip kits come with them....
Offline bigblock73
  • Yeller
« Reply #2 on: May 27, 2007, 11:58:50 pm »
Another option instead of using shock extenders, is to use drop shocks.
Jeff
'73 swb 2wd
73-87.com
Offline bigbubba87
« Reply #3 on: May 28, 2007, 11:12:28 am »
but is'nt that plate going on the bottom,once the axel gets fliped?
so the shock would be the same distance as before flip?
« Reply #4 on: May 29, 2007, 05:10:16 pm »
The plate will be on the bottom , but it won't be near where the original brackets were, and definitely not in the same orientation.  It is much easier to just get the flip kit with the extenders or drop shocks...
Offline bigbubba87
« Reply #5 on: May 29, 2007, 08:24:19 pm »
do ya have a link to the extenders
Offline Lon
« Reply #6 on: May 29, 2007, 09:56:25 pm »
A good flip kit will have shock extenders. I used a Bell Tech flip prior to bagging my truck. It had the extenders and shocks with the kit.
1984 GMC Sierra. Air Bagged but mostly stock.
Offline Mr79C10
  • My 79 C-10 Project
    • My 79 C10 Project
« Reply #7 on: May 31, 2007, 05:24:20 pm »
This is the kit I just got. Installing this weekend.
*House of Friends
