Author Topic: TPI onto 86 Block  (Read 191658 times)
Offline 123 pugsy
Re: TPI onto 86 Block
« Reply #165 on: November 12, 2007, 05:45:40 pm »
I was referring to YOUR exhaust, have you thought about installing duals? I've already got dual 2.25" exhaust w/ cats and glasspacks on mine. Changing the modulator valve is a matter of me being lazy, its been like this since I bought it in late summer/early fall of last year.
Sorry about that.
I'm not thinking about duallies. I have a FULL 2-1/2" exhaust. Every turn is made from a stainless steel elbow. Absolutely zero squished bends or turns. This should be more than sufficient and I believe better for low end torque.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #166 on: November 12, 2007, 05:50:36 pm »
My supply house has it in stock for $68 bucks. The Standard is cheaper but on back order
PM sent.
Pugsy
Pugsy
76 C10 LWB
TPI 350
« Reply #167 on: November 12, 2007, 05:53:41 pm »
Hey Pugsy if you want me to get it for you I will and then you can just paypal me the $ plus shipping. If you want me to get it I'll order it in the morning. Let me know.
Offline 123 pugsy
« Reply #168 on: November 12, 2007, 06:42:38 pm »
Ya sure, sounds good. ;D
Thanks
Pugsy
76 C10 LWB
TPI 350
« Reply #169 on: November 13, 2007, 10:10:58 am »
OK I ordered it. I'll let you know when it comes in.
Offline 123 pugsy
« Reply #170 on: November 13, 2007, 10:14:09 am »
Thanks.
Pugsy
76 C10 LWB
TPI 350
« Reply #171 on: November 17, 2007, 01:44:18 am »
Pugsy, he said it should be in on Monday... I'll let you know.
Offline 123 pugsy
« Reply #172 on: November 17, 2007, 05:51:06 am »
Right on.  ;D
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #173 on: November 17, 2007, 03:01:57 pm »
Shot after the spring chop:
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #174 on: November 18, 2007, 11:52:35 am »
I took out about 1-1/2" off the rear lifting blocks and now have no rake. I think it looks alot better. Doesn't look like a 4x4 wannabe anymore.
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
« Reply #175 on: November 19, 2007, 04:37:06 pm »
Before and after the spring chop:
Pugsy
76 C10 LWB
TPI 350
« Reply #176 on: November 19, 2007, 05:13:38 pm »
DANG that did bring it down!!  What springs did you use?
Offline werewolfx13
« Reply #177 on: November 19, 2007, 07:20:47 pm »
Nice work..I woulda left the old stance myself, but to each their own. ;)
Chris
'83 Chevy c10 Silverado SWB
Offline 123 pugsy
« Reply #178 on: November 19, 2007, 07:56:58 pm »
According to the diameter (.826") of the springs, they were the heavy duty Moog's for a big block truck. I had ordered regular duty springs, but these were in the box and I didn't know. I just cut 1 coil off and took out 1-1/2" off the lift blocks.
Front end alignment tomorrow.
I liked it at first, but it didn't grow on me. Don't know why......
Pugsy
76 C10 LWB
TPI 350
Offline 123 pugsy
Dyno
« Reply #179 on: November 21, 2007, 05:05:03 am »
Dyno results: ( at the wheels)
The blue line is the first pull. The air/fuel looks like it drops to 10:1 but the guy says its lower as that's where the computer flat lines.
The red line is the second pull with the air filter hose disconnected. It picked up 22 HP and 20 Ft/LBS of torque. The air/fuel ratio came up also but not to where it should be.The guy says I should install headers and the ratio should come up some more.
That looks like one reason for such poor fuel economy.
Pugsy
76 C10 LWB
TPI 350
