Author Topic: 79 not starting when hot  (Read 6795 times)
Offline 75 C20
« on: June 25, 2007, 05:17:09 pm »
my 79 with a 350 will start up reall easy and good when it sits over night or for awhile but if i drive it for a while and then shut it off then come back a little bit later it wont start. i was thinking it might be my coil but i dont really know for sure. i have yet to find weather it is a fuel deliverly problem or if i am not getting spark- i replaced the ignition control modeul a couple weeks ago also.
« Last Edit: June 25, 2007, 07:47:39 pm by 75 C20 »
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: 79 not starting when hot
« Reply #1 on: June 25, 2007, 09:38:28 pm »
You probably have a bad distributor pick up coil
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #2 on: June 25, 2007, 10:33:15 pm »
Vile is right!  My 79 did the same thing.  She would run great.  Then after stopping for 10 or 15 minutes and trying to turn it back on, she would turn, and turn and turn w/out firing.  It was getting no spark.  When the distributor cooled for about 15 to 20 minutes w/ the breather off (so it would cool down more) it would start again.  I replaced the simple stuff like coil, rotor, cap, checked the timing, etc...I finally got fed up and threw a different distributor in it (i have like four of them--I collect a few when i go to the salvage yard) and it fixed the problem...still have that distributor in it and she runs like a champ.
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #3 on: June 26, 2007, 01:46:23 am »
does it have headers? could be heat soak on the starter.
Offline 75 C20
« Reply #4 on: June 26, 2007, 07:44:55 pm »
no the engine is all stock
Offline Mr79C10
  • My 79 C-10 Project
    • My 79 C10 Project
« Reply #5 on: July 01, 2007, 06:13:37 am »
My 79 has just started that. I have a inline 6 but symptoms are the same, And I have a brand new Optima batt. So  I made up my mind just to buy a new dist. instead of rebuilding it.  Be here this week for next weekend t do list.
*House of Friends
Offline mpellis
« Reply #6 on: July 02, 2007, 05:13:33 pm »
I kind of have the same problem with my 82 K10.  The difference is I can get it started if I hold the gas pedal down while cranking it over. I just had a shop install an Edelbrock carb with electric choke. The truck starts fine when cold. How does this electric choke know when to open or close?
« Last Edit: July 02, 2007, 07:48:20 pm by mpellis »
« Reply #7 on: July 02, 2007, 09:28:44 pm »
An electric choke is wired off of your oil pressure switch. When the engine cools down so does the choke coil and closes the choke flap. At the same time it forces the fast idle cam onto it's step and when you start the engine you are supposed to simply depress the throttle 1/2 way (not pump it) and crank the engine until it starts. When you release your foot from the accelerator the choke coil being closed receives current flow through the oil pressure switch circuit. After a short period of time the current flowing through the coil causes it to heat up and expand opening the choke flap and knocking the fast idle cam off it's step. As long as current is flowing through the choke coil it will remain open. When you shut the engine off current flow stops and as the choke coil cools it's closes the choke again.
