Author Topic: electri windows  (Read 6020 times)
Offline mikewb
electri windows
« on: June 27, 2007, 02:47:51 pm »
on an electric door does anybody know how i can wire it to work if my truck didnt come with power windows. as in which wires are for the drivers door and what does what.
Re: electri windows
« Reply #1 on: June 27, 2007, 03:02:18 pm »
you can either run a donor harness or run the wires yourself. Just print out the schematic and then physically measure out what you'll need.
Offline mikewb
Re: electri windows
« Reply #2 on: June 27, 2007, 03:09:33 pm »
where should i run the wires to?
Re: electri windows
« Reply #3 on: June 27, 2007, 05:24:36 pm »
As in where to power them from?  The fuse panel.  If you find one in the salvage yard, you can pull the power window/lock harness out.  It is an additional circuit for these trucks.
Offline mikewb
Re: electri windows
« Reply #4 on: June 28, 2007, 01:43:23 pm »
the orange, blue , and black wires go to the drivers door. which ones go to power and which ones to ground?
Re: electri windows
« Reply #5 on: June 28, 2007, 02:23:06 pm »
76 Pink goes to the fuse box, 150 black goes to the bus bar ground.  (It is on the drivers side a pillar behind the dash.)
