Author Topic: Oil pressure gauge/sending unit  (Read 5890 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« on: July 01, 2007, 09:56:15 pm »
76 chevy c20 2wd 350. On the 454 I took out of the truck there was just a line ran down to the hole by the oil filter. There was no oil pressure switch. Well the factory gauge would show at about the half mark first started and about the quarter mark idling warmed up. I hooked this line up to the hole by the distributor on the 350. It shows about the quarter mark when first started and 0 when warmed up and idling. Driving down the road makes it go up a little.
I know the engine doesn't really have 0 oil pressure or the valves would be clattering and engine would be knocking and so on. I looked up on partsamerica website and it shows a oil pressure switch used for the 350 and 454 which has an electric spade on the end.
My question is what is on the truck and what is supposed to be on the truck so I can get it right and have true readings.
Offline Prong
Re: Oil pressure gauge/sending unit
« Reply #1 on: July 02, 2007, 01:24:37 am »
Your mechanical gauge is correct. They went to electric in 78. Is there no spot near the filter on your 350 to install the line as before?
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: July 02, 2007, 11:03:50 am »
yes theres a place for it by the oil filter on the 350. Do you think changing it to down there would make a difference in the reading?
« Reply #3 on: July 02, 2007, 12:59:22 pm »
Hook up an external auxiliary gauge to verify the accuracy of the gauge in your truck. You should convert to a standard oil pressure gauge and dump the oil line set up
