Author Topic: Fuel Line ?  (Read 3530 times)
Offline stevieray36
Fuel Line ?
« on: July 13, 2007, 01:03:57 pm »
There are two metal fuel lines running up the passenger side frame rail. One supplies gas from the tank to the fuel pump. Someone stuck a a bolt in a short piece of rubber hose clamped to the other metal line. Is this the fuel tank vent line which should connect to the canister?
Re: Fuel Line ?
« Reply #1 on: July 13, 2007, 02:05:23 pm »
one is feed one is return
Offline stevieray36
Re: Fuel Line ?
« Reply #2 on: July 16, 2007, 07:35:45 am »
Should I purchase a fuel pump with a return line? Or can I just keep it plugged and use as is? What is the advantage to having a return line?
Offline ccz145a
Re: Fuel Line ?
« Reply #3 on: July 22, 2007, 10:54:51 pm »
My guess is that the pump lasts longer if it can pump as designed. With a return line the pump can pump at full volume, just some of it goes back to the tank.
