Members Rides
73-87chevytrucks.com - Jimmy Project
4
9
Topic: 73-87chevytrucks.com - Jimmy Project (Read 112379 times)
Re: 73-87chevytrucks.com - Jimmy Project
Reply #15 on:
July 23, 2007, 10:43:33 pm »
Saturday July 21st, 2007
I had one remaining brake/fuel line frame clamp left and it was under the engine mount stand. It took about 45 minutes to get it off with a box end wrench.
Pulled out the new EFI lines and laid them out so I can get the shipping bend out, pulled the carb and had to stop to go get a family portrait.
Reply #16 on:
August 14, 2007, 05:12:10 pm »
Monday, Aug 13th
: put on the blocking plate for the fuel pump, cleaned up the TPI plenum for final assembly along with the Throttle Body pieces. Put the high pressure pump and new filter on the 87-91 Blazer sending unit. Getting ready to pull the intake manifold to start putting the TPI on the engine. I still need to get a Vette fuel rail.
Last Edit: November 06, 2007, 11:29:16 am by Captkaos
Reply #17 on:
August 20, 2007, 04:23:32 pm »
Saturday Aug 18th, 2007
had to clean up one of the runners had some gunk still in one of them, still soaking it. Got the plenum all cleaned up and ready. Pull the top of the motor down and removed the 4 bbl intake, set the TPI base in place and got the gas tank out and realized the spare sender I had was for a deeper fuel tank, Guess I will be getting an EFI tank now.
also realized I need a sending unit piece that will allow me to use the stock sender and the EFI sensor...
Last Edit: November 06, 2007, 11:33:09 am by Captkaos
Reply #18 on:
November 06, 2007, 11:42:05 am »
Saturday Sep 8th, 2007
Instead of getting an EFI tank I ordered a 25g sending unit for a EFI truck from Advance (PN# FG12K). Took 5 days to arrive.
Saturday Sep 15th, 2007
Took all main TPI pieces and cleaned them up and painted them over the next few days.
Reply #19 on:
November 06, 2007, 11:56:19 am »
Friday Sep 28th, 2007
Opened the package from S&P for the rear exit/feed and SS fuel lines along with the 9th injector elimination kit and started piecing it together. Cut the return line off and installed the rear feed connection. Found that they had not sent one of the pieces for the regulator.
Saturday Sep 29th, 2007
Painted the remainder of the TPI Parts
Reply #20 on:
November 06, 2007, 12:00:43 pm »
Monday Oct 1st, 2007
Installed the EFI unit in the stock gas tank. Pulled out the EFI fuel lines recieved from Classic Tube and started straightening the shipping bends out.
Tuesday Oct 2st, 2007
placed the Feed and Return lines in the chassis only to discover the poor exhaust system that I had put on previously that was a POOR attempt will need to be removed from the truck and made again. This time the Turbo will be present for mockup.
Reply #21 on:
November 06, 2007, 12:03:18 pm »
Saturday Oct 6th, 2007
drilled and tapped the front feed line of the fuel rail with 1/8th in pipe tap. This was NOT fun.
Reply #22 on:
November 06, 2007, 12:06:03 pm »
Wednesday Oct 31st, 2007
Ordered some 42lb injectors
Saturday Nov 4th, 2007
Pressed in the 9th injector block off plug from S&P. This wasn't fun either
Reply #23 on:
November 19, 2007, 03:57:24 pm »
Friday November 16th, 2007:
Injectors were delivered USPS on 14th, but weren't left. I had to go pick them up at the Post office.
Saturday November 17th, 2007:
got all the bolts to the manifold off, but from the shady job of building the y-pipe from some an exhaust shop (that I didn't pay for) I now have to cut the Y-pipe to get it out...
DnStClr
Reply #24 on:
November 29, 2007, 09:47:01 pm »
Whew. Great project Chris. If you weren't running the turbos would you just use the 7730 ecm instead of the 7749?
Don
87 Chevy Silverado
Reply #25 on:
November 30, 2007, 10:28:56 am »
Yes, I would just use an F-body ECM if I wasn't turboing it.
Reply #26 on:
December 03, 2007, 05:56:35 pm »
Friday, November 30th, 2007:
Picked up the 700R4 trans that need rebuilt to replace the TH350 currently in place.
Saturday December 1st, 2007:
Got the fuel lines installed and clamped down short of 2 clips I would like to add on top of the missing fuel filter clamp. Put splash shield on the TPI base and then installed it. Put the S&P oil pressure tee on (for running factory sender and the TPI sender) and the thing stripped out. Yippie! Couldn't find my water outlet, have NO clue where it went so I got to get a new one. Installed the 42lb injectors in the fuel rail. Debating on whether I will run the EGR or make a block off for it.
Saturday December 2nd, 2007:
Went to several parts stores to find a brass fitting that would fit under the TPI Base to replace the S&P piece, finally found the 2 I needed.
Updated Pics coming soon.
Last Edit: December 09, 2007, 09:53:33 pm by Captkaos
Reply #27 on:
December 09, 2007, 10:02:16 pm »
Saturday December 8th, 2007:
Pulled the intake back off to put the new brass fitting in the block for the sensors. Installed the fuel rail assembly and hooked up the rear feed fuel supply and return lines. Definitely not going to run an EGR due to no room, so I have to make a block-off for it. Ordered a water outlet.
Sunday December 9th, 2007:
Picked up the water neck (gotta paint it) and then searched all local stores for the parts to rebuild the 85 TPI distributor, with no luck.
123 pugsy
Reply #28 on:
December 10, 2007, 05:42:56 am »
Looking good Chris.
Pugsy
76 C10 LWB
TPI 350
Reply #29 on:
December 17, 2007, 01:05:14 pm »
Saturday December 15th, 2007
Didn't get much accomplished except for making a EGR block-off for the intake.
4
9
Members Rides
