Engine/Drivetrain
carb rebuld, quadrajet
Topic: carb rebuld, quadrajet (Read 5470 times)
dumbucket1
Too Many Trucks
Coal Hauler
July 16, 2007, 03:09:58 pm »
I rebuilt my quadrajet because it kept stalling when you put the truck in drive or came to a stop light. After the rebuild it now idles smooth and really wants to smoke the tires accellerating, but it still wants to stall when put into gear or when come to a stop light, raising the idle does not help any at all. What should I look for, maybe vacuum leak at the primary throttle shaft? There are no vacuum leaks otherwise. 76 c20 350 auto.
Re: carb rebuld, quadrajet
July 16, 2007, 03:21:28 pm »
check your timing.
⌠ŻŻŻŻŻ' [☼===☼]
dumbucket1
Too Many Trucks
Coal Hauler
July 17, 2007, 03:56:10 am »
nope not timing, I put a borrowed carb on it and no stalling issues when put into gear with that carb.
July 17, 2007, 04:02:54 pm »
Then you need to pull it back off and make sure you remove the jets, and run some mig wire through all the holes. Clean everything really good and blow it out with compressed air. /recheck your float settings and did you seal up the casting plugs with epoxy?
⌠ŻŻŻŻŻ' [☼===☼]
dumbucket1
Too Many Trucks
Coal Hauler
July 18, 2007, 12:22:07 pm »
will do as instructed and no I did not fill casting plugs with anything.
July 18, 2007, 06:30:16 pm »
make sure you do!
⌠ŻŻŻŻŻ' [☼===☼]
dumbucket1
Too Many Trucks
Coal Hauler
July 22, 2007, 06:12:50 pm »
ok took the carb back off, back apart ran mig wire through all holes and blew out with compressed air as instructed. Stalling problems solved. Thanks vile..
July 22, 2007, 10:06:45 pm »
Glad to hear!
edit spelling
⌠ŻŻŻŻŻ' [☼===☼]
Engine/Drivetrain
