Author Topic: Whats better Blocks or springs??  (Read 18467 times)
Offline Timber
Re: Whats better Blocks or springs??
« Reply #15 on: November 28, 2007, 10:08:47 pm »
I've used 4" blocks in the rear under new leaf springs before.  It worked fine, but I didn't have much more power than stock.
Offline 79shortbed
« Reply #16 on: November 29, 2007, 07:16:55 am »
Big long ladder bars defeat the whole point of a lift though?!!! ???  Unless you are doing it ONLY for vanity reasons.
no, big long ladder bars, or traction bars which ever term you want to use, help to prevent axle wrap and keep thinks from breaking. many high powered trucks are running them. im not sure why they would defeat the point of a lift.
Offline xtremjeepn
« Reply #17 on: November 29, 2007, 04:34:06 pm »
Because the point of a lift (other than vanity) is to GAIN ground clearance!!!!  If you lift it 4" but have to add 8" deep ladder bars down 3 feet of the frame length you have defeated the purpose. Not to mention that many ladder bar set ups restict articulation, cause bind when the suspension is at full stuff etc etc.
There are plenty of ways to fight axle wrap other than ladder bars. Especially if you want to retain the ability to tow.
Cole
Restomod Crew Cab Short box on 37"s
Offline 79shortbed
« Reply #18 on: November 29, 2007, 04:55:53 pm »
well if thats the case, why lift a 88-current ifs chevy? the drop down that holds the transfercase and LCA's interfer with ground clearance.
ladder bars go no lower than the rear end its self, so the chances of them getting hung up on something is slim.
many trucks with big lifts wont be crawling so having to worrie about flex isnt an issue. A big lifted leaf spring truck will not have much flex period. If people want flex, they use a coil over style setup with link bars and if set up correct the link bars put a stop to axle wrap.
I use my ford for work, i need it lifted to get down the right-of-ways on the pipeline because it can be muddy, the chances of me needing to go places that my truck running on 10" of lift on 37's cant go are none. i still use my truck to tow and long ladder bars will work just fine for me.
and i use it for play...
« Last Edit: November 29, 2007, 05:04:31 pm by 79shortbed »
Offline xtremjeepn
« Reply #19 on: November 29, 2007, 06:07:44 pm »
Haha,   You obvioulsy don't get over to ColoradoK5.com or Pirate4x4.com much do ya?
There are TONS and TONS of guys wheeling (rockcrawling) these rigs.
First off the 88+ IFS trucks SUCK for off road. Secondly, 10" of lift for 37s on one of these??????  I have 37s with only 4" of lift thanks to the Bushwhacker flares. And no need for ladder bars with only 4" lift.
Most guys avoid the lift springs and blocks altogether buy flipping the rear shackle.
That's not wheeling, that is a waterhole on the way to the trail.
« Last Edit: November 29, 2007, 06:13:47 pm by xtremjeepn »
Cole
« Reply #20 on: November 29, 2007, 06:12:21 pm »
sorry to bring up anold post but to much power+lift blocks=
LOL
Built FORD tough!
Offline 79shortbed
« Reply #21 on: November 29, 2007, 07:10:40 pm »
no i really dont go over on those sites, that is some nice flex but doesnt the aid of the fliped shackle help? that little water hole is just about the only thing i can take my truck in, my trucks to long to take on little trails, if i had a "trail rig" them yea that little water hole would silly. i built my truck for work. back on topic, ladder bars help in axle wrap...no matter how much lift you have.
Offline xtremjeepn
« Reply #22 on: November 30, 2007, 09:31:33 am »
A short overload spring will take care of axle wrap too. But it will allow the spring to flex up and down, just not twist and also help with ground clearance.
Cole
